how long for type r cams to break in
the oiling system of a vtec engine and the valve train style, you should be fine.
break in on like a chevy v8 is critical because the lobes are splash oiled from the crank. thats why you have to break in those cams. i just took it around the block, adjusted the valves and changed the oil and called it a day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slosol »</TD></TR><TR><TD CLASS="quote">so i need to adjust the valves
uh...yea. also, once installed, take the car to red line in first gear and then drop to 2nd and redline it again...cams are broken in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acydphryck »</TD></TR><TR><TD CLASS="quote">
thats the only way to go
