how long for type r cams to break in
Mr. Badwrench
Re: how long for type r cams to break in (slosol)
the oiling system of a vtec engine and the valve train style, you should be fine.
break in on like a chevy v8 is critical because the lobes are splash oiled from the crank. thats why you have to break in those cams. i just took it around the block, adjusted the valves and changed the oil and called it a day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slosol »</TD></TR><TR><TD CLASS="quote">so i need to adjust the valves
uh...yea. also, once installed, take the car to red line in first gear and then drop to 2nd and redline it again...cams are broken in
Re: how long for type r cams to break in (acydphryck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acydphryck »</TD></TR><TR><TD CLASS="quote">
uh...yea. also, once installed, take the car to red line in first gear and then drop to 2nd and redline it again...cams are broken in </TD></TR></TABLE>
thats the only way to go
H-T White Ops
They say to run it at various RPM's, keeping 'em under 6K for about 100 miles or so. City traffic would be perfect. Just avoid constant RPM's and reving over 6K. Should be fine.
