prelude o2 sensor/voltage problem
Old Jan 10, 2004 | 04:16 PM
yOnKiNaToR's Avatar
Default prelude o2 sensor/voltage problem
i got a '92 prelude SI with a jdm h22a in it. as soon as i push the gas hard it bogs and vtec is very very weak. it used to give me a code 41. so i replaced the o2 sensor with a one that hmotorsonline sent me and that code went away but now it's giving me a code 1 and it's still bogging...so i checked the voltage with a multimeter and it goes anywhere from .1-.9 kinda slow. when i give it any throttle at all it goes down to 0-.1. also when i pull out the white wire connected to the ECU at D14 i don't get a check engine light is this normal? should i replace the sensor again? is it the wires?
Old Jan 11, 2004 | 09:46 AM
yOnKiNaToR's Avatar
Default Re: prelude o2 sensor/voltage problem (yOnKiNaToR)
ttt
924drb20
Dec 14, 2010 10:36 AM
92_VTEC_lude
May 3, 2007 05:34 AM
EGY8
Jul 16, 2006 01:26 PM
delguiner
Jun 29, 2004 07:10 AM
