CX to a DX swap quetions
Old Jan 10, 2004 | 03:42 PM
al3e's Avatar
Default CX to a DX swap quetions
i know my cx is a 8v and dx is 16 v both non vtec... i can use pretty much EVERYTHING from my CX on the DX(d16b7)... or will i have to use the D distriburot and alt........right? should be a realy simple swap...right?
my plans are to run the dx then get a vtec head and some other goodies...
flames...bring em on... help would be better tho
Old Jan 10, 2004 | 04:06 PM
ProJectCvic's Avatar
Default Re: CX to a DX swap quetions (al3e)
distributor and alternator the same. I believe the only diferrent is the single wire 02 in the cX and the 4 wire o2 sensor in the dx. Straight forward swap. Piece of cake. Good luck, i pretty sure alot of guy here will give you the dx part for free or dirt cheap.
Modified by ProJectCvic at 10:42 PM 1/10/2004
Old Jan 10, 2004 | 05:21 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by al3e &raquo;</TD></TR><TR><TD CLASS="quote">i know my cx is a 8v and dx is 16 v both non vtec... i can use pretty much EVERYTHING from my CX on the DX(d16b7)... or will i have to use the D distriburot and alt........right? should be a realy simple swap...right?</TD></TR></TABLE>
All 92-95 civic dizzy are the same and alt. You have to wire up teh 4-wire 02 if you do not use the DX harness.
O2 Sensor Input - WHT to D14 (needs to be a shielded wire)
Heater Control - BLK to A6
Sensor Ground - GRN to D22
Sensor Voltage - BLK to A25 or B1
Old Jan 11, 2004 | 08:27 AM
al3e's Avatar
Default Re: CX to a DX swap quetions (turbogixxer)
i have to wire the 4 wire 02... whats that mean...how do i do that ?
Old Jan 11, 2004 | 12:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote"> You have to wire up the 4-wire 02 if you do not use the DX harness (aka, if you use the CX harness)</TD></TR></TABLE>
Old Jan 11, 2004 | 01:33 PM
al3e's Avatar
...gee thanks ...doesnt help me ...how do i 04 wire to 02.....
Old Jan 11, 2004 | 03:41 PM
VTECVillain's Avatar
Don't be an ***. If you would look a few posts above, turbogixxer already told you the pinouts for the 4 wire O2 wiring.....
If that's not enough then do a search. It's been covered on here numerous times by myself and quite a few others.
Old Jan 11, 2004 | 06:50 PM
Default Re: CX to a DX swap quetions (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">Don't be an ***. </TD></TR></TABLE>
Turbogixxer spelled it out for you. Learned to read.
Old Jan 12, 2004 | 08:52 AM
al3e's Avatar
bmy bad i didnt see the other part turbogixxer posted I read his post after staying up all night.
Old Jan 12, 2004 | 11:40 AM
Frosty901's Avatar
al3e
Your avatar owns haha havent seen that in so long.
Old Jan 13, 2004 | 06:04 AM
al3e's Avatar
Default Re: CX to a DX swap quetions (Frosty901)
yeah owns cause i made it... i have a few others but its kinda hard to see the sav tricks hehe
dispnoiracer
May 1, 2006 09:49 AM
idriveanimport
Sep 24, 2003 01:31 PM
HUBB
10
Apr 8, 2003 11:56 PM
tyronebiggums
18
Apr 1, 2003 08:41 PM
EGWEEGY
27
Dec 9, 2002 10:10 PM
