Air/Fuel Gauges, Useless or Helpful
Old Jan 10, 2004 | 02:45 PM
doublejz's Avatar
Default Air/Fuel Gauges, Useless or Helpful
I am debating on putting a a/f gauge in my car just to see how its running. I will not be using a WB02 just a stock 02 sensor. Whats your opinion on them?
Old Jan 10, 2004 | 05:18 PM
Crono139's Avatar
Default Re: Air/Fuel Gauges, Useless or Helpful (doublejz)
Just more bling, IMO.
Old Jan 10, 2004 | 07:27 PM
d16tuner's Avatar
People who can't afford wideband still deserve to know 'about' where they are at WOT!!
Old Jan 10, 2004 | 07:38 PM
Team 4R's Avatar
get an egt instead.... it only costs 4x as much. at least it's accurate though.
Old Jan 10, 2004 | 07:57 PM
XxslayerxX's Avatar
how do you read the egt's?
Old Jan 10, 2004 | 08:11 PM
fengxzhang's Avatar
the hotter the temp, I believe closer to 1600 then you are running really lean.
Old Jan 11, 2004 | 02:12 PM
Mighty's Avatar
I believe most of them are junk.
If you cant afford an EGT or wideband O2 then get an A/F meter. I like the one from http://www.dawesdevices.com
Its easier to read and more accurate than most A/F meters.
Old Jan 11, 2004 | 02:46 PM
XxslayerxX's Avatar
If you had a wideband o2 sensor and a a/f gauge. Would it be accurate?
Old Jan 11, 2004 | 03:45 PM
onePOINTsix's Avatar
Default Re: (XxslayerxX)
build one thats accurate
Old Jan 11, 2004 | 03:53 PM
Bailhatch's Avatar
Default Re: (fengxzhang)
EGT temp at the right A/F ratio is different for all cars. you can't just say 1500 is good unless you tested it with a WBO2. the temp can go up depending on ignition timing, too lean or too rich etc.... So IMO an EGT is far more useless than a lightup A/F meter.
Old Jan 11, 2004 | 07:19 PM
photec3's Avatar
Default Re: (Sideout)
what do r1 r2 and c1 do?
Old Jan 11, 2004 | 07:29 PM
doublejz's Avatar
Default Re: (photec3)
im gonna guess resistor 1 and 2 voltage and capacitor makes it to the correct voltage
Old Jan 11, 2004 | 08:40 PM
PHiZ's Avatar
Default Re: (doublejz)
I'm going to go ahead and say that is an O2 display, not really a meter.
Here are some options:
http://www.suprastore.com/gredairfuelk.html
this link provided the most information about the product, I'm not sure that it is a real wideband, details are still a little sketchy, could be a nice device.
http://www.aempower.com/product_ems.asp
"Gauge type Wideband UEGO controller" has a nice form factor and is a true wideband.
Here is some background on widebands:
https://honda-tech.com/zerothread?id=635792
-PHiZ
Old Jan 11, 2004 | 09:51 PM
DavidR's Avatar
Default Re: (PHiZ)
http://www.plxdevices.com
Old Jan 13, 2004 | 04:18 PM
doublejz's Avatar
Default Re: (DavidR)
bump
Old Jan 13, 2004 | 06:28 PM
R1 and R2 calibrate the LM3914, C1 smooths it out so it dosent flicker
Old Jan 13, 2004 | 06:40 PM
xxdprussxx's Avatar
a/f guages are prety good and i think accurate
Old Jan 13, 2004 | 06:47 PM
junbb1's Avatar
yeah. they are not as good as a wide band because of the slight delay. thare are definatly some that are better than others though. see my sig i am selling probably the best A/f guage on th market before stepping into a true wide band. it really is a nice piece.
Old Jan 13, 2004 | 07:17 PM
StyleTEG's Avatar
Default Re: (junbb1)
Nothing you would want to use for tunning, but its good to know that when you are at WOT you are running rich and not lean.
Old Jan 14, 2004 | 05:31 AM
doublejz's Avatar
bump
nytosc
Aug 23, 2008 07:40 AM
KStuned
Oct 6, 2004 11:39 AM
MugenPoweredLude
Dec 29, 2002 12:18 AM
89 CRX SI
Sep 19, 2002 07:10 AM
CalvitoSol
Jul 6, 2002 07:00 PM
