how to check igniter and coil in a distributor (did search)
Old Jan 10, 2004 | 02:06 PM
spoolineh2's Avatar
Default how to check igniter and coil in a distributor (did search)
Recently my b16 eg decided to die on me. I pulled the plugs and I am not getting any spark. I am pretty confident that it is my distributor. I was just wondering how I would go about checking the coil and igniter. It is a 94 gsr distributor. Thanks for any info
Old Jan 10, 2004 | 05:46 PM
93FastLs's Avatar
Default Re: how to check igniter and coil in a distributor (ill94hatch)
with the ignition off , remove the distributor cap
remove the 2 screws to disconnect the black and yellow wire from terminal A and White /blue from terminal B of the coil...
use and ohmmeter ,check resistance between terminals. replace the coil is it's not in spec..
check the primary winding resistance between terminals A and B is 0.6 - 0.8 ohms
chec that the secondary winding resistance between terminal A and coil tower is
9760 - 14640
replace coil if not in spec..
this is off a 90-93 LS distributor..im pretty sure it's the same
Old Jan 19, 2004 | 08:44 PM
spoolineh2's Avatar
Default Re: how to check igniter and coil in a distributor (93FastLs)
thanks
Old Jan 19, 2004 | 09:03 PM
boostn420's Avatar
If you want to check the ignitor, disconnect ir from the coil and put a test light at the coil wires. Crank the engine, you should have a blining light if the ignitor works.
Old Jan 19, 2004 | 09:19 PM
hondatim's Avatar
Default Re: how to check igniter and coil in a distributor (boostn420)
Need to use a logic probe or graphing meter in order to properly test for signal and its integrity (i.e.. signature waveform) to and from the ignitor. A regular 12v test light does not work. And just testing for light blinking only gives half the story of the ignitors condition.
To check the signal from the ignitor to the coil, check black wire with yellow tracer going from ignitor to ignition coil.
To check the signal from the ECM to the ignitor, test at yellow wire with green tracer at the ignitor.
Hope this helps
Old Apr 17, 2004 | 06:57 AM
jyipdragon's Avatar
Hi there,
How do I replace the igniter in my 1990 Integra?
A couple of weeks ago, my Integra stalled without notice. I tried restarting it, even though it cranked over, it wouldn't start. I thought I flooded the engine ... I waited a day and the car started just fine. However at 2000 rpm and higher the car started to sputter. The tech needle jumps like crazy.
I check the plugs and there was no spark. I removed a spark plug and notice that the plugs were extremely dirty.
I then proceeded to replace the spark plugs, spark plug wires, and then the ignition coil. All of which didn't solve the problem.
Now ... after doing some further research and reading ... I think its the Igniter itself.
How do I go about replacing the igniter on my car?
Old Apr 17, 2004 | 12:28 PM
Lscivichatch92's Avatar
Default Re: how to check igniter and coil in a distributor (jyipdragon)
its fairly easy u just find the igniter (the little rectangle thing with 4 plugs 3 on top 1 on the side) undo all the wires unscrew the two screws holding it in place on the distributor and pull it out its not hard at all
Edit: i didnt go through how to take off the distributor and cap and rotor cuz u said u changed ur coil already and u should know how to do all that
Old Jan 8, 2012 | 06:44 PM
james haskle's Avatar
Icon2 Re: how to check igniter and coil in a distributor (boostn420)
Hope this helps
Old Jan 8, 2012 | 06:50 PM
Default Re: how to check igniter and coil in a distributor (did search)
hondatim, Can you further explain these tests? Just what am I looking for? My Honda manual just says to check these wires...check what? My Haynes manual lists resistance but does not say resistance between what...My coil seems to Ohm out to specs, the igniter will flash a light, but I have no spark. I do have voltage to the distributor with the key on (pos. and neg. terminals). Thanks!
joncowden
Mar 11, 2008 06:14 AM
Hybrid Invasion
Nov 25, 2007 11:50 PM
DookieHowser
Sep 4, 2007 08:40 AM
prjctwhteg
Nov 10, 2006 04:36 PM
duckming
Jun 5, 2003 05:17 PM
