B20. dont know what route to go
Old Jan 9, 2004 | 08:13 PM
JDMlyfestyle's Avatar
Default B20. dont know what route to go
Ive been researching lately and none of them talk about reliability. Should i go all motor on the B20 or go Turbo. Id like to be able to run about 14-17lbs on the street if i went turbo. also i was wondering what is a good redline on a B20. thanks and flames and all input is welcomed
Old Jan 9, 2004 | 08:29 PM
joe_bocc's Avatar
Default Re: B20. dont know what route to go (JDMlifestyle)
If you plan to run 14-17 lbs of boost your going to need to resleeve for sure. All motor its not a neccessity. If your priority is reliability then perhaps 14-17 lbs. is a little high. Consider something more like 7-8 lbs.
From what I've heard, when mated to a short geared tranny like the B16 or Type R the all motor B20 makes a quick car.
Old Jan 9, 2004 | 09:28 PM
SleepnCiViC's Avatar
b20 have weak internals. 17 psi will be no easy task by far, will def need work
Old Jan 9, 2004 | 09:33 PM
Im going to get one of the import builder.com blocks run a 9.0 c/r
Old Jan 9, 2004 | 11:22 PM
Bull_head360's Avatar
Default Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">Im going to get one of the import builder.com blocks run a 9.0 c/r</TD></TR></TABLE>
that would be a great start but i think all you'd need would be 10lbs daily driven, wouldn't that be fast enough, (250 hp?)then throw in a 17lb spring when you go racing (along with some tuning), but whutever you wanna do...You have to spend extra money to make a turbo motor reliable if ur gonna run that kind of boost
Old Jan 9, 2004 | 11:24 PM
Ya@inlinePRO's Avatar
concentrate on the tuning if you go turbo
prjctwhteg
Oct 21, 2006 01:53 PM
SiRk
Jul 21, 2005 10:00 PM
cxhb
May 26, 2005 09:14 PM
sPaRk'iT
Dec 28, 2003 09:32 AM
1fastcx
Dec 30, 2001 04:04 PM
