DAMN SCREW WON'T COME LOOSE. any suggestions???
Old Jan 9, 2004 | 04:21 PM
AznJohn33's Avatar
Default DAMN SCREW WON'T COME LOOSE. any suggestions???
i'm changing the side mirrors on my car right now and I'm taking off the screws so I can remove the door panel...but that one screw that's behind the inside door-handle won't come loose!!! I've tried different screwdriver sizes, I've tried "trying harder." NOTHING WORKS~!
Maybe i'm just posting because i feel so defeated and PHUCKED but is there any tips to get this fugger off?
Old Jan 9, 2004 | 04:49 PM
00VTEC's Avatar
Default Re: DAMN SCREW WON'T COME LOOSE. any suggestions??? (AznJohn33)
soak it with wd-40
Old Jan 9, 2004 | 05:28 PM
Bimmer99's Avatar
sounds like you stripped the head of the screw . the only way to get it out is to drill off the screw head either that try to use a small set of vicegrips to work it out but there isn't too much room there to do that
Old Jan 9, 2004 | 06:38 PM
smurfey002's Avatar
impact driver.
Old Jan 9, 2004 | 06:46 PM
mr.beeks's Avatar
Default Re: DAMN SCREW WON'T COME LOOSE. any suggestions??? (Bimmer99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bimmer99 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you stripped the head of the screw . the only way to get it out is to drill off the screw head either that try to use a small set of vicegrips to work it out but there isn't too much room there to do that </TD></TR></TABLE>
drill is the best impact you will destroy it..
Old Jan 9, 2004 | 11:00 PM
nY's FiNeSt's Avatar
Default Re: DAMN SCREW WON'T COME LOOSE. any suggestions??? (00VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00VTEC &raquo;</TD></TR><TR><TD CLASS="quote">soak it with wd-40</TD></TR></TABLE>
Old Jan 9, 2004 | 11:03 PM
B2FiNiTY's Avatar
Default Re: DAMN SCREW WON'T COME LOOSE. any suggestions??? (mr.beeks)
Drill it out time.
Old Jan 10, 2004 | 08:22 AM
Blue Streak's Avatar
Default Re: DAMN SCREW WON'T COME LOOSE. any suggestions??? (B2FiNiTY)
vices work good you can also try and take a dremel and cut a slit in the head and try usiing a flathead
Old Jan 10, 2004 | 08:58 AM
Big Teggie's Avatar
Just drill it out if the head is stripped
DB1_559
Nov 27, 2006 02:11 PM
ExiledinIN
12
Nov 30, 2003 05:36 PM
FcUK It.
17
Oct 9, 2003 03:18 PM
ih8danoles
Apr 21, 2003 12:21 PM
type autox
Jan 21, 2002 06:55 PM
