Autometer Oil Pressure Gauge Qs
Old Jan 9, 2004 | 04:03 PM
Phaze2 Mike's Avatar
Default Autometer Oil Pressure Gauge Qs
Car: 95 CX
Setup: jdm d15b w/greddy kit and FMIC
Issue: Installed the gauge w/ brand new autometer sender. When the car is on, it hovers around 75, then when throttle applied gets near 100, but when u just sit there long enough, itll chill at 25. Car seems to be fine, no oil leaks, 4qts of oil in yesterday. The sender is mounted on a T fitting which plugs into the block, then has the oil feed line, then the sender. Imagine a T rotated 90 degrees to your right. What do you think the problem is.
Old Jan 9, 2004 | 04:06 PM
Sonny's Avatar
Default Re: Autometer Oil Pressure Gauge Qs (yellowfever)
Are you concerned about the high numbers? Those numbers look ok to me. My car shows about the same. As the engine heats up and the oil thins out, the pressure will go down when you're sitting there idling.
Sonny
Old Jan 9, 2004 | 04:22 PM
My concern was the 25.
Old Jan 9, 2004 | 04:48 PM
T-RO's Avatar
Now i dont know if it matters BUT...
I have a mechanical Oil press gauge and it goes down to about 15 after its been warmed up and i'm just idling.
As long as the arm goes up while accelerating you should be ok. Thats what i've been told at least
Old Jan 9, 2004 | 06:27 PM
speedworks's Avatar
Default Re: (T-RO)
25 hot is normal on most hondas. 80 on the high side is also normal. you have no problems.
HXMan
Oct 19, 2012 07:00 AM
ActiveAero
21
Jan 29, 2007 12:53 AM
Sassafrass
17
Dec 14, 2006 02:10 PM
pcguy760
Jul 2, 2006 10:17 AM
ShortbusEK
Jan 14, 2003 12:29 PM
