sportline spring installation
Old Jan 9, 2004 | 02:26 PM
972drcordex's Avatar
Default sportline spring installation
Im wondering if im getting a fair deal. Im paying this local tuner shop to install my eibach's for 180. Is that good or should I keep looking.
Old Jan 9, 2004 | 02:33 PM
Legendaryyaj's Avatar
Default Re: sportline spring installation (972drcordex)
if ur not lazy do it urself...save money and learn something...its not that hard. i think 180 sounds good.
Old Jan 9, 2004 | 02:35 PM
jwogen1's Avatar
if you dont know anyone that has a shop and will help you do it or do it for cheaper, then you will end up paying anywhere from $50-80hr for labor. cant hurt to check around, as long as they are reputable shops.
Old Jan 9, 2004 | 03:41 PM
.bagged's Avatar
get together with some tuner friends of yours and spend an afternoon learning how to do it. suspension swaps are a great learning experience. its not that hard either.. just dig in an get dirty..any questions thats what we are here for...
Old Jan 9, 2004 | 03:52 PM
Default Re: sportline spring installation (bagged93accord)
heres the thing, i dont think we can get access to a lift
and dont we also need a machine to compress the springs?
Old Jan 9, 2004 | 04:00 PM
typertn's Avatar
you dont have to have a lift to do the springs, only a floor jack that can lift one whole end of the car at a time. I did my second set of springs with a floor jack and rented a spring compressor from auto zone. Since it was my first time it took me about 4 hours. On an accord there are like three bolts that hold the front strut from the top, one that holds it to the damper, and one that holds the damper to the lower control arm. Then there are like two bolts that hold the brake line to the stut. On the back there are two bolts at the top, and then one through bolt that holds the strut to the lower control arm. i took the caliper off the back disk, it made manuevering the oblong strut a little easier in the confined area.
Old Jan 9, 2004 | 04:08 PM
Default Re: sportline spring installation (typertn)
OK, heres a big question, stock theres about a 4inch gap between my tire and top of my wheel well. Now Eibach says it will lower it aroudn 1.8. I really dont want more than a 2.5 in drop. Can anyone who has had these tell me if it really only lowers it 2inches?
Old Jan 9, 2004 | 08:18 PM
jwogen1's Avatar
i have a 94 accord on eibach sportlines, which is 1.8" front and 1.7" rear. it is a perfect ride height for me and autox. there is approx. an inch of gap left from the wheel well lip to the tire.
Old Jan 9, 2004 | 08:21 PM
jwogen1's Avatar
Default Re: sportline spring installation (jwogen1)
if you want to go lower than that, there are some other spings that will put you around 2.0"-2.25", but i think you said you already have the sportlines.....
Old Jan 9, 2004 | 11:37 PM
iam7head's Avatar
You'll end up having about 2 finger of wheel gap, which is far better than the grand canyon wheel gap for stock accord.
you should measure the before and after(after it settle) height, from the center the rims to the fender edge.
Just do it yourself, it's very easy but it just takes time.
Old Jan 10, 2004 | 09:57 AM
slvrcivic97's Avatar
Default Re: sportline spring installation (iam7head)
Figure it out and do it yourself Dumb newbs.
ketchup
15
Mar 18, 2008 04:51 PM
killaj12
16
Nov 15, 2004 11:25 PM
Maxboost808
Apr 6, 2004 07:56 PM
96IntegraLS4DR
Feb 27, 2002 11:04 AM
