searched (turbo oil temp)
I have a B16 and a t3/t4 turbo on the car what i want to know is with moblie one what should oil temps be and should i buy a gauge because i make long 3 or 4 hour runs with the car down the highway in the summer and the car will run at 4000 rpm to 5000 rpm for 3 or 4 hours and i am worried i might want a oil cooler for the car in addition to the oil to water one that is on the car already from the factory. Because i think the cooler the oil the better is this true.
I dont think you will run into any problems, but I dont see what adding another oil cooler could hurt and their not all that expensive. I still dont think it is necessary though.
well i am running mobil 1 10w 30 and if i could run a oil cooler i would but who makes a kit or where should i pull the oil from i can put another hole in the oil pan with out a problem.
