Header installation...
Old Sep 27, 2001 | 09:43 PM
976's Avatar
976
New User
Default Header installation...
I am ready to install my DC ceramic header. It came with one gasket four the header and exhaust manifold, aren't others needed, such as for the down-pipe? I don't want to break my O2 sensor wires, or even snap it, what should I watch out for? Any other tips would be great, I want this installation to go flawless, I don't want to worry if my header will crack, any precations? Thanks alot...
Old Sep 28, 2001 | 11:42 AM
976's Avatar
976
New User
Default Re: Header installation... (B21A)
TTT
Old Sep 28, 2001 | 02:46 PM
rainforest's Avatar
no, you can use your old exhaust doughnut unless it is really bad. Thats the one that connects the header to the cat.
Old Sep 29, 2001 | 04:08 PM
976's Avatar
976
New User
Default Re: Header installation... (rainforest)
Ah, okay thanks. So there are only two gaskets for my header to cat?
Old Sep 29, 2001 | 04:39 PM
johng's Avatar
There should be the main manifold gasket that's between the head and the exhaust manifold (header), and the thick donut in the end of the exhaust manifold (header). Both can typically be reused, and the donut can be a pain to remove depending on age. That's it for gaskets, unless you have a two piece header, or you're taking apart the B pipe. Be sure to use "anti-seize" on the O2 sensor threads.
[Modified by johng, 5:41 PM 9/29/2001]
Old Sep 29, 2001 | 04:53 PM
hondachick81's Avatar
Default Re: Header installation... (johng)
tourqe the bolts to spec.. make sure you start from the middle and work your way out when you snug the nuts,, so the gasket flattens properly.. let the engine warm to temp and recheck the nuts after it cools... then recheck recheck recheck
civic girl ,,shane89Z good luck
Old Sep 29, 2001 | 08:38 PM
976's Avatar
976
New User
Default Re: Header installation... (CivicGirl114)
Thanks for the great info, guys/girls. I need a torque wrench...
Old Sep 30, 2001 | 05:54 PM
9integra2's Avatar
New User
When I got my 2-piece DC header, it only came with the two donut o-rings that go in between the 2-pieces. I'm surprised they gave you a head/header gasket because I remember having to reuse my old one. If you did get the 2-piece header, but didn't receive the 2 o-rings, get those first. Someone on a forced induction board had generic o-rings that kept on blowing out, so try to find the OEM DC o-rings. If you got the one-piece header, disregard everything said on this paragraph.
When I had to take off my stock exhaust manifold, it was almost impossible to get the three screws that hold the two pieces together off. Be prepared to invest in a portable torch so you can cook the nuts before you break them off. I rounded the bolts and had to buy a dremel, then use 10,000 cutting wheels to get that off. What a PITA!!!
[Modified by 9integra2, 2:57 AM 10/1/2001]
Old Aug 20, 2004 | 10:26 AM
jlsmi2's Avatar
Default Re: Header installation... (9integra2)
I have a DC Sports JDM ITR DC2 header that I plan to install pretty soon; I've been delayed unfortunately.
This header came with nothing -- no gaskets, no header bolts, no donut. I had to buy the donut from honda ($35) bc the inside diameter 2.5" is larger than the factory header, hence no way to reuse the old donut.
Has anyone bought a similar header and received header bolts, head/header gasket?
How much should I expect to pay for a nice set of header bolts and the gasket b/n the header and the head..
thanks
stiness101
Jan 11, 2006 10:12 AM
RUBZERK
Apr 2, 2004 11:09 PM
robbieshonda
Mar 4, 2003 04:33 PM
JSJ EG6
14
Sep 5, 2002 01:38 AM
JumbosGS-R
Aug 6, 2001 02:02 PM
