h23 or b20a rods in b18a
Old Jan 9, 2004 | 10:15 AM
civdx94's Avatar
Default h23 or b20a rods in b18a
i was wondering if h23 rods or b20a rods could be put in a b18a for a better r/s ratio. i already have the pistons covered i just couldn t find the rod journal size.
Old Jan 9, 2004 | 10:59 AM
rtype11's Avatar
Default Re: h23 or b20a rods in b18a (civdx94)
b20 rods are the same, the B20 motor is just a an overbored B18A. what is the big and small end diameters on the H23 rod? what is the length, what is the journal/bearing width, I've never heard of this swap.
Old Jan 9, 2004 | 11:21 AM
civdx94's Avatar
no my friend i was referring to a b20A, the early prelude motor. the lengths on these rods are 141.5, but i don't know much else about them. the h23 are the same length, giving the ls a 1.59 r/s ratio.
Old Jan 9, 2004 | 01:40 PM
dfoxengr's Avatar
u shouldve said b20a5
Old Jan 9, 2004 | 01:44 PM
rtype11's Avatar
well in that case you sound like a the old one follower, looking for the right rod ratio, fine, ask larry on the endyn board I am sure he has all this stuff on graphs. what is your idea? what are you truing to build? stroker destoke???? use the B17 crank with LS rods in a B18A for some fun for example. are you sure that B 20 wasnt a H series????
Old Jan 9, 2004 | 03:42 PM
civdx94's Avatar
i'm trying to build an ls with a better r/s ratio. stock crank with longer rods and custom pistons. i m gonna use hayabusa pistons and bush the rods
Old Jan 9, 2004 | 05:16 PM
dfoxengr's Avatar
Default Re: (civdx94)
those are 81mm pistons?
Old Jan 9, 2004 | 05:34 PM
civdx94's Avatar
Default Re: (hybridvteceg)
yep 81mm, 17mm wrist pin, and a compression height of about 23.5mm
ericstambaugh07
Dec 18, 2006 06:18 PM
slayersluck
Oct 1, 2006 03:26 PM
EvR
Jul 30, 2005 11:17 PM
TS4L
Jul 29, 2003 05:18 PM
Smurfylude
May 20, 2002 03:15 PM
