???'S for those with an Infinity Baselink
Old Jan 9, 2004 | 08:50 AM
GreenBean's Avatar
Default ???'S for those with an Infinity Baselink
I see in the installation manual that you can wire it up multiple ways, I want to use line lever converters to convert the allready crossed over signal at the bose sub and input that. Is this the best way?...I am keeping my factory bose sterio with the disc changer in it...I just want a little more low end.
Old Jan 9, 2004 | 11:28 AM
jspec rsx's Avatar
What I did was I got a RCA converter, tapped it in to the signal coming from the bose woofer, tapped the remote wire from the remote from the bose woofer and added the power wire. You can also used the line level since the basslink has the connections for it just tap it in to any of the speaker, run a power wire, don't need a remote, since when you use a line level there's auto on/off feature on the basslink
Old Jan 9, 2004 | 11:38 AM
MueveloNYC's Avatar
Default Re: (jspec rsx)
yeah that's the way to go. Originally I had then tapped to the rear speakers but then swapped them to RCA's when I got a new headunit. Getting a new headunit will definitely help the overall sound quality.
Old Jan 9, 2004 | 12:33 PM
GreenBean's Avatar
Default Re: (MueveloNYC)
Thats cool, but I want to keep the factory head unit. I'll go with the RCA converter and run some good power wire for it...Then use the amp turn on lead for the Baselink. Thanks guys...Does it hit good, and do any of you have the remote control?
Old Jan 13, 2004 | 08:45 AM
jspec rsx's Avatar
it's decent, sounds nice clean and clear deep low ends....however if you want the car next to you to be able to hear you or people in a parking lot to hear you...the basslink is not good to go ...for the money it's worth it
projectcivicsl
Audio / Security / Video
11
Mar 25, 2005 08:29 PM
alien6067
Feb 16, 2005 05:38 PM
macaronak
Sep 3, 2004 07:43 AM
foofighter
Aug 24, 2003 01:24 PM
Fooser
12
Mar 7, 2002 06:15 AM
