Power for AMP
Old Mar 5, 2002 | 02:21 PM
Fooser's Avatar
Default Power for AMP
It there anything I can use to conduct the power current over the line? It seems like the line is losing power towards the end. I think its probably about 8-10' long so I'm not sure what to do. I have heard of people using something to do this I'm just not sure what it is.
Old Mar 5, 2002 | 07:21 PM
MugenSi00's Avatar
Default Re: Power for AMP (Fooser)
increase the wire size
Old Mar 6, 2002 | 06:16 AM
Focal Energy's Avatar
Default Re: Power for AMP (MugenSi00)
Actually, if you're losing power near the end, you need to check your wire out completely. Sounds like you might be using some cheap-a$$ wire (Not knocking you, some wire is just like that! ). If I were you, I'd see if you have exposed some of the wire as you were running it. Sounds like it's grounding out before it gets to the amp. Buy a pretty high quality wire with a thick casing. DON'T buy Monster wire, you're paying for a name. Go to a car audio shop and buy their generic wire. As long as the casing is thick enough and you buy the correct guage wire, you'll be JUST fine! Just cause it has Monster Wire on it doesn't mean that it's the best. Anyway, good luck.
For 8-10', he shouldn't be losing enough power in the line to even notice. The ONLY way he'd be able to tell that he's losing power is if it were either a bad wire (corroded in the casing), or he's grounding out somewhere. Just my experience though.
[Modified by Focal Energy, 10:19 AM 3/6/2002]
Old Mar 6, 2002 | 06:20 AM
Fooser's Avatar
Default Re: Power for AMP (Focal Energy)
Well I found out what the problem was. I had a fake amp. Plugged in a real one and it hit like crazy. I'm pissed.
Old Mar 6, 2002 | 11:22 AM
SiClone's Avatar
I had a fake amp....
Never heard of that one....
Old Mar 6, 2002 | 01:53 PM
GSRaCeRbOI's Avatar
Default Re: Power for AMP (SiClone)
yeah all i gotta say is.. theres sum shady azz ppl on the internet...
Old Mar 6, 2002 | 02:04 PM
TexTeg's Avatar
Where did you get your amp from so the rest of us know to avoid it?
Old Mar 6, 2002 | 02:10 PM
Fooser's Avatar
Default Re: Power for AMP (TexTeg)
An aquantances friend. Just dont buy from someone you don't know. To bee even more safe go to the store and buy so that you can get a warrenty on the item.
Will post pics tonight of the amp. Its decieving. So if anyone has a way to put pics on the net let me know so I can show everyone what a fake looks like.
[Modified by Fooser, 11:11 PM 3/6/2002]
Old Mar 6, 2002 | 03:33 PM
o_Rage_o's Avatar
fake or cheap? You said inside there was chips..rather than a coil.it could have been a **** amp, might have had something blown inside or even just hooked up to an improper load (maybe bridged when it could'nt handle it??) It was definetly not 800watts, because that's a max rating, the 30 watts it prob put out per channel were definetly not enough to bump.
Just trying to make sure that you don't go shoot your friend without taking into consideration some of these things first
Old Mar 6, 2002 | 05:16 PM
Fooser's Avatar
Default Re: Power for AMP (o_Rage_o)
I got pics need somewhere to upload them.
Old Mar 6, 2002 | 05:53 PM
ThePunk's Avatar
http:www.imagestation.com
Old Mar 6, 2002 | 07:09 PM
Default Re: Power for AMP (ThePunk)
If you don't want to sign up for an account, you can just send them to me and I'll post them from imagestation for you.
doobydoo13@hotmail.com
[Modified by Focal Energy, 11:10 PM 3/6/2002]
Old Mar 7, 2002 | 06:15 AM
Fooser's Avatar
I got pics posted on other thread.
https://honda-tech.com/zerothread?id=139411
hondalove323
Honda Civic (2001 - 2005)
16
Jul 16, 2008 12:01 AM
hybrid1990crx
Audio / Security / Video
14
Jul 14, 2006 06:46 AM
cd5_2NR
Apr 20, 2003 09:47 PM
vtec94
Feb 14, 2003 01:57 AM
PearlWhiteAccord
Jun 18, 2002 05:17 AM
