difference between b16b and b16a2 (99 si)
Old Jan 9, 2004 | 04:09 AM
sebmour jdm's Avatar
Default difference between b16b and b16a2 (99 si)
I was wondering if the difference were only camshaft with proper valvetrain, higher compression piston that made the difference between those two engines.
Thank you for your help and knowledge.
Old Jan 9, 2004 | 07:42 AM
PHiZ's Avatar
Default Re: difference between b16b and b16a2 (sebmour jdm)
b16b is a B18 block, where B16a is a B16/B17 block.
-PHiZ
Old Jan 9, 2004 | 08:00 AM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sebmour jdm &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if the difference were only camshaft with proper valvetrain, higher compression piston that made the difference between those two engines.
Thank you for your help and knowledge. </TD></TR></TABLE>
as sayd above b16b block is 7mm taller, different crank and rods also
thangnhocngheo
Oct 23, 2010 08:50 AM
tobe1424
Mar 13, 2006 06:01 AM
Damon B.
17
Jun 30, 2002 01:41 PM
BLKCRX
Jun 1, 2002 10:07 PM
BLKCRX
Jun 1, 2002 09:57 PM
