TurboXS RFL BOV Washer Help....
THose washers go inside the BOV if its too loud for u... So lets say u want to quiet down the RFL, then u stick the washers in, which makes the spring inside stiffer and harder to open, its just for adjustability.
are they washers or more like something that the BOV attaches to? i beleive, they come with a steel one, and also an aluminum one... if this is what you are talking about. use the one for your application, and put the other ones on a shelf or something
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VNTEC »</TD></TR><TR><TD CLASS="quote">THose washers go inside the BOV if its too loud for u... So lets say u want to quiet down the RFL, then u stick the washers in, which makes the spring inside stiffer and harder to open, its just for adjustability.</TD></TR></TABLE>
ummm those washers are not there for u to make it quieter/louder.
So your saying that if u want to make it quieter, just add all the washers in? Wouldnt u think that if it makes the spring stiffer that it wouldnt blow off right and get compressor surge at low psi?
back to topic, those washers are for when you are boosting more to stiffen the spring so that it wont open under heavy boost. It IS adjustability, but not for loudness
So your saying that if u want to make it quieter, just add all the washers in? Wouldnt u think that if it makes the spring stiffer that it wouldnt blow off right and get compressor surge at low psi? back to topic, those washers are for when you are boosting more to stiffen the spring so that it wont open under heavy boost. It IS adjustability, but not for loudness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic »</TD></TR><TR><TD CLASS="quote"> are they washers or more like something that the BOV attaches to? i beleive, they come with a steel one, and also an aluminum one... if this is what you are talking about. use the one for your application, and put the other ones on a shelf or something</TD></TR></TABLE>
nice rear diffuser
i just bought one from ht member cant wait to get it
nice rear diffuser
