8 Ohm sub at 4 ohm?
Old Jan 8, 2004 | 05:01 PM
brickonwheels's Avatar
Default 8 Ohm sub at 4 ohm?
exactly what the title says, what would happen if i were to run an 8 ohm sub rated at 125 watts at 4 ohms?
Old Jan 8, 2004 | 05:24 PM
[626]phixionEF91's Avatar
Default Re: 8 Ohm sub at 4 ohm? (brickonwheels)
if it is a DVC sub with 2 8 ohm voice coils then u can run it at 4 ohm. otherwise it is impossible (i think) if it is a 8 ohm svc sub then thats what the amp will read it as and will send the power accordingly. unless there is some other method i have never seen b4 there is no way you can disguise a 8 ohm load as a 4ohm
Old Jan 8, 2004 | 06:06 PM
ATF Kuk's Avatar
Default Re: 8 Ohm sub at 4 ohm? ([626]phixionEF91)
correct me if im wrong, depending on amp, it would cut the power rating in half. so u would get about 75 watts to it.
Old Jan 8, 2004 | 06:22 PM
i sure as hell wouldn;t want to do that
Old Jan 9, 2004 | 12:54 PM
Default Re: (brickonwheels)
what is the RMS and what type of sub is it?
Old Jan 9, 2004 | 01:35 PM
The sub is a Kicker Comp vr10-8, it is rated at 125rms.
Old Jan 9, 2004 | 01:36 PM
I have got some info on another one of my posts that i should bridge the two subs to the amp so it will read as 8 ohms. That way i'll get 250 watts from each.
Old Jan 9, 2004 | 01:37 PM
ah thats a DVC that means if u wire it parrelell it will be ran as a 4 ohm load
whats the rms on your amp for a 4 ohm load and what type of amp is it?
Old Jan 9, 2004 | 01:41 PM
the amp is a rockford fosgate 501s, at 4 ohm it is 125rms or 250 rms
Old Jan 9, 2004 | 01:42 PM
I think i might return the subs and either get the 4 0hm version or go ahead and get credit for them and buy 2 better subs that will handle 250 rms better
Old Jan 9, 2004 | 02:05 PM
my mistake there, at 40hms, 125x2, at 2 ohms 250x2
Old Jan 9, 2004 | 02:17 PM
oh ouch
hummm let me look at the specs of the amp
Old Jan 9, 2004 | 02:23 PM
Default Re: ([626]phixionEF91)
ok it say that it has a peak bridged RMS power of 500X1 watts, im guessing thats at a 4 ohm load. u shoudl be fine as far as teh RMS being 125 on your sub i believe tahts per voice coil thus the rms would be 250
this is your amp http://www.sounddomain.com/sku/ROC501S
i couldnt find any specs on your sub are u sure its a VR with two 8 ohm coils?
Old Jan 9, 2004 | 02:46 PM
it is a single coil. Right now i am looking at 2 MTX Audio Thunder6000 series 10" single coil subs. They are rated at 250rms and for two i could get them at 170 from sounddomain.com
Old Jan 9, 2004 | 03:23 PM
if its a single coil its a c10 not a vr
DONT GET MTX subs NOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!
kicker is teh best u can get under 100 bux
ive gone through 11 subs trying to replace my kicker
stick with one or 2 kickers preferable one c12 4 ohm
my gosh my was beautiful
Old Jan 9, 2004 | 03:35 PM
ATF Kuk's Avatar
dont listen to anyone. they dont now wut theyre talking about. this is wut u do. since u have subs at 8 ohms each, run it parallel connection to the amp. which does 250. when u wire it into parallel, it will make the connection to te amp into 4 ohms. then u will get 250 from the amp and since u have 2 subs it will share the power which will make 125 to each sub.
stop re-asking the same ******* questions. go do that and stop asking anymore questions.
Old Jan 9, 2004 | 09:02 PM
someone's a little pissy, but thanks for the help
Old Jan 10, 2004 | 03:01 AM
Westrock2000's Avatar
Well actually you could run a good power resistor in parrellel with the sub and it would give you 4 ohms plus one other side effect. It would raise the Q of the speaker quite a bit.
Whats Q? Well its the quality of resonance at the resonant point of a driver.
So lets say you have a speaker that has a Fs of 60Hz (I know not something you guys would admit too, but its highly realistic) and the sub has a Q of 0.33. It would have a frequency response something similar to 1 in the picture. You can see it starts to roll off at 200Hz and by 70Hz your down by 12dB, which aint too bad for music, but many of you would probably be turning that bass up for the extra umph. Plus many of you set your Low Pass filters in the 100-120Hz range anyways so everything above that doesn't matter much.
Anyways back to the Q. Number 2 is a Q of 0.6 and 3 is a Q of 1.0. You can see that as the Q increases the freq response gets amplified around that point. Now this isn't very HiFi, but what it does give you is a very pronounced effect in the 120-80Hz range, which is the bass that you percieve as being the loudest, because you can feel it and hear it. Also notice that at 70Hz on Q1.0 your at -9dB, while the Q0.33 is at -12dB, well that translates into half the power needed to make 1.0 the same volume as 0.33. So now 50Watts is as loud as 100Watts was on the stock driver. Of course were doing this by adding a power resistor in parrellel, so thats gonna soak up some power, but the Freq response will have the biggest effect.
Remember your results may vary, please consult your physican, void in Montana, family and freinds are not eligible. This is food for thought.
There are better ways to extend low end, this is just one easy way.
EDIT: One thing I should add. Although a 8 ohm speaker and a 8 ohm resistor equal 4 ohms perfectly when in parellel, I should note that increaseing the resistance of the resistor will channel more current the driver, since it has less resistance, but will have little effect on the overall resistance.
for example
driver.....resistor.....parellel ohms
8...........8..........4
8...........9..........4.235294118
8...........10........4.444444444
8...........11........4.631578947
8...........12........4.8
8...........13........4.952380952
8...........14........5.090909091
8...........15........5.217391304
8...........16........5.333333333
8...........17........5.44
8...........18........5.538461538
8...........20........5.714285714
Plus as the resistor gets bigger more power will be diverted to the driver since electrons flow through the path of least resistance.
Modified by Westrock2000 at 6:30 AM 1/10/2004
Old Jan 10, 2004 | 06:38 AM
foz's Avatar
foz
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brickonwheels &raquo;</TD></TR><TR><TD CLASS="quote">someone's a little pissy, but thanks for the help</TD></TR></TABLE>
Pissy perhaps, but the most dead-on do what he said and get on with enjoying your kickers
Old Jan 10, 2004 | 11:22 AM
vividsport's Avatar
have had excellent results with MTX and Kicker subs - its all about the box! Not just the sub. The reason the guy got a little "pissy" is that this is the most common problem in car audio - people think they know something and then apply it wrong, then someone else has to mop up the mess for something that should have been as simple as he explained it in his post the first time. You are just collateral damage. The good news is that if you do what he said (providing the subs are in the proper box/enclosure) your setup should rock!
Old Jan 11, 2004 | 04:13 PM
Torridcivic's Avatar
Default Re: (vividsport)
Why do resistors only start having an effect at 80Hz? Doesn't seem like that is the target frequency of any music I listen to on a sub.
Old Jan 15, 2004 | 01:24 AM
Default Re: (Torridcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Torridcivic &raquo;</TD></TR><TR><TD CLASS="quote">Why do resistors only start having an effect at 80Hz? Doesn't seem like that is the target frequency of any music I listen to on a sub. </TD></TR></TABLE>
The resistor is doing nothing...its mearly emphasizing the sound of the speaker. The speaker has a resonance at that frequency...remember it was a hypothetical setup, your results may vary. That was a sealed enclosure set for 0.707 box Q. It could be totally different in a large ported enclosure tuned to 30Hz.
By saying you don't listen to much music in the 80Hz range what do you mean? Thats where most music bass is, in the 40-120Hz range....more like 50-100Hz.
Old Jan 15, 2004 | 05:08 AM
snoochtodanooch's Avatar
i don't think he would be going for the resistor method, he just needs to read an audio book and his problems will be answered
m.glisson003
Audio / Security / Video
18
Aug 15, 2011 06:17 PM
Civic321
Aug 25, 2004 04:00 PM
brickonwheels
Feb 1, 2004 09:44 AM
redteg1
Apr 9, 2002 08:46 PM
woodog
Dec 17, 2001 11:08 PM
