playing subs with trunk open
Old Jan 14, 2004 | 02:59 PM
roots01's Avatar
Default playing subs with trunk open
Someone told me not to turn up my stereo and let my subs hit with the trunk open. They said that is does something with the air space. I think it's bs but I just wanted to check it out.
Old Jan 14, 2004 | 03:31 PM
97Civic-R's Avatar
Default Re: playing subs with trunk open (roots01)
as long as the subs are in a good enclosure it doesn't do anything to them..it won't sound good because they're playing in open air..thats about it
Old Jan 14, 2004 | 05:19 PM
snoochtodanooch's Avatar
whoever told you that was using some weak info. Some subs are even designed for non enclosed use, with just an infinite baffle. If your sub is in a box, opening the trunk would have nothing to do with causing the sub to fail. Thats like saying if i took that same sub, and put it in a suv truck with the windows and sunroof open, that the sub would blow. Your stereo is fine as long as you are using a sealed or small ported box.
Old Jan 15, 2004 | 02:56 AM
roots01's Avatar
Default Re: (snoochtodanooch)
that's what i thought, i just wanted to check that out. Thanks for the info I'll tell him.
Old Jan 15, 2004 | 05:49 AM
foz's Avatar
foz
Default Re: (roots01)
I agree with what everyone else has posted so far, with the exception of free-air subs, (which you probably don't have) it is not great for the sub to play a free-air sub with the trunk open, if their in a box then it's fine, they just won't sound too hot at full volume
Old Jan 15, 2004 | 07:05 AM
rcurley55's Avatar
New User
Default Re: (foz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foz &raquo;</TD></TR><TR><TD CLASS="quote">I agree with what everyone else has posted so far, with the exception of free-air subs, (which you probably don't have) it is not great for the sub to play a free-air sub with the trunk open, if their in a box then it's fine, they just won't sound too hot at full volume</TD></TR></TABLE>
THere is nothing more free air then venting your subs to the outside world!! There's nothing wrong with that application. Mic Wallace in his IASCA mitsu (I think that's what it is) has 4 ID10v3's mounted in an infinite baffle config in his spare tire well. So the subs vent to the outside world. He used some type of fabric to let air out but keep any moisture away from the subs (can't recall the type) - so it is ok to do.
Old Jan 15, 2004 | 07:49 AM
foz's Avatar
foz
Default Re: (rcurley55)
wallace's free-air's where tuned to work that way, and although venting to the outside, he still had his trunk to work as a chamber (just as a trunk acts as a chamber for free-airs typically) however in the typical installation when the trunk is open, the free-airs loose some of their chamber, which will cause them to distort easier and wear them out prematurely therefore not being the greatest way to treat them
cpl rampage
Audio / Security / Video
10
Jun 22, 2009 04:58 AM
littledude56
Jan 30, 2009 05:58 AM
93b18civic
Jan 4, 2004 05:21 PM
4doorex
Oct 24, 2003 10:57 PM
lilbennyxx
10
Oct 11, 2003 12:10 PM
