no heat!?!
Old Jan 8, 2004 | 05:09 AM
Zer0DazE's Avatar
Default no heat!?!
95 hatch with a single cam motor
its damn cold out, and my heater is giving me nothing but cold/warm air.
the car heats up normally
the slider and valve to control the heat are all working.
when the car is monving i can get some heat, but not a lot
when i stop, its cold
(yes, it worked last winter)
occasionally i get a heat spike. it noramally sits just between the half mark and C. everyonce in a while it spikes up above the half point (i get no heat then), and then it drops back down again.
the thermostat is 3 weeks old (OEM Honda) there is pleanty of coolant.
i was thinking maybe an air bubble, or the radiator cap... or both. any idea?
Old Jan 8, 2004 | 05:11 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: no heat!?! (Zer0DazE)
bad heater coil?
I had this problem on on of my honda's... i replaced the heater coil and it fixed my problem' might wanna check that out'
Old Jan 8, 2004 | 05:21 AM
Sliced Beard's Avatar
Default Re: no heat!?! (kKdARIAN)
it may be a bad heater coil
a friend just had this problem and it sucked
vvvvv check out signature vvvvv
Old Jan 8, 2004 | 01:54 PM
JSPECHB's Avatar
Default Re: no heat!?! (dirtyd463)
Its your heater coil for sure dude. For the time being you can always put sticks on your passenger side floor mat and light a wire.
ninjaturtleEG
Jan 15, 2010 11:21 AM
Liquidgsr
Dec 27, 2005 05:41 AM
91' LS-VTEC
Dec 19, 2004 08:27 PM
BigChris
Apr 26, 2003 01:50 PM
ex_crxer
Apr 6, 2003 06:52 AM
