Anyone tryed JUN 3 cams in a turbo motor
Old Jan 8, 2004 | 12:10 AM
10secondhatch
Guest
Posts: n/a
Default Anyone tryed JUN 3 cams in a turbo motor
Im currently running CTR cams in my turbo motor and was wondering if anyones tryed JUN 3s in there turbo motor, But before u post and tell me that to much duration isnt good for turbo because ive been hearing that for years i want to hear from someone whos tryed these cams or somthing similar, and if HP peaked at a higher rpm like an NA motor, Oh yea im not worried about rough idle or mid range just intrested in peak power (7Kto10K). Thanks
Old Jan 8, 2004 | 02:18 AM
ScrapinSi's Avatar
Default Re: Anyone tryed JUN 3 cams in a turbo motor (RUSTYSHACKLFERD)
nobody has tried them because there is no point. They are made for NATURALLY ASPIRATED.
Old Jan 8, 2004 | 02:26 AM
rjardy's Avatar
Default Re: Anyone tryed JUN 3 cams in a turbo motor (ScrapinSi)
True, the overlap will kill you. not turbo freindly. And no you cant dial all the over lap out with cam gears.
stock is turbo friendly
Rob
Old Jan 8, 2004 | 05:08 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUSTYSHACKLFERD &raquo;</TD></TR><TR><TD CLASS="quote">But before u post and tell me that to much duration isnt good for turbo because ive been hearing that for years i want to hear from someone whos tryed these cams or somthing similar
The reason why you won't get any feedback is because most people won't try that combo. There's a reason why parts are designed to work together. You can't just expect to slap all these parts together and "hope" that it makes power.
If you want more peak HP, run a bigger turbo. Just make sure your motor is built to rev that high.
Old Jan 8, 2004 | 05:45 AM
mike1114's Avatar
Default Re: Anyone tryed JUN 3 cams in a turbo motor (98CTRCoupe)
DON'T SWITCH!
I have crower stage one vtec cams and the overlap is killing me horribly on the dyno! I'm switching to some stock GSR's this weekend.
My dyno chart also has a huge (like almost 50whp) drop when vtec kicks in cause of these cams.
I couldn't imagine how much power would be lost from even bigger cams!!
Old Jan 8, 2004 | 07:08 AM
The Crow's Avatar
Default Re: Anyone tryed JUN 3 cams in a turbo motor (mike1114)
I saw a guy a year or so ago making big power with toda b's on his turbo car. I wish someone would try some Skunk S1's and see what happens.
If you have money to burn, go for it. If not stick with your CTR's.
Modified by The Crow at 5:20 PM 1/8/2004
Old Jan 8, 2004 | 07:24 AM
PrecisionH23a's Avatar
Default Re: Anyone tryed JUN 3 cams in a turbo motor (The Crow)
I am pretty sure JUN has done a test with the stage 3's with a turbo motor... If you read the box the cams come in they specifically say 'These cams are great for naturally aspirated set-ups. They are not designed however for Forced Induction.'
Old Jan 8, 2004 | 09:45 AM
10secondhatch
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">DON'T SWITCH!
I couldn't imagine how much power would be lost from even bigger cams!!</TD></TR></TABLE>
If your loosing 50 hp when vtec kicks im not sure if the cams, my cams are bigger than crower 401s and im fine, i think your problem is elsewhere.
Old Jan 8, 2004 | 09:55 AM
Boltz's Avatar
someone here is running toda spec c's in his built b16 that revs to 10,800..... from what ive read he likes them
im sure hell show up on this thread sooner or later
Old Jan 8, 2004 | 10:04 AM
10secondhatch
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Crow &raquo;</TD></TR><TR><TD CLASS="quote">I saw a guy a year or so ago making big power with toda b's on his turbo car. I wish someone won't try some Skunk S1's and see what happens.
If you have money to burn, go for it. If not stick with your CTR's.</TD></TR></TABLE>
Thanks man thats what i wanted to hear, In that hci mag they built a 87x84 gsr w/skunk stage 2 cams and they claimed like 650hp on 25lbs (using engine dyno). Buts thats just what i read dont know if its true. S2S2 are bigger than JUN3 and it seemed to worked for them.
Old Jan 8, 2004 | 04:50 PM
AlphaMike's Avatar
Dave (dabullet) ran Jun 2's in his race car with god results. Here's the link to the car.
https://honda-tech.com/zerothread?id=666332
lsvtec_hatchback
Apr 7, 2009 05:12 AM
SPOOLINmatt
Feb 26, 2008 03:30 PM
gsrpedro
Feb 9, 2008 10:14 PM
Tatakai
Jul 16, 2005 12:46 PM
