LOW Temp Reading
Old Jan 7, 2004 | 10:07 PM
dustinsterk's Avatar
Default LOW Temp Reading
Okay, my temp guage never gets anywhere close to half way. Most of the time it stays BELOW the cold mark (VTEC takes a long time to kick in). Both radiator hoses are warm (upper and lower)......I DO have heat (takes forever to get warm though), so should I replace the thermostat? Also I never have heard my fan for the radiator kick on. I jumped the fan at the plug and it DOES turn on. Does that mean that the sensor needs replaced as well as the thermostat?????
Thanks for the help.
--Dustin
Old Jan 7, 2004 | 10:18 PM
mmuller's Avatar
Mad Scientist
Default Re: LOW Temp Reading (dustinsterk)
yeah, replace thermostat
Old Jan 7, 2004 | 10:39 PM
Default Re: LOW Temp Reading (mmuller)
Okay so the sensor is fine?
Old Jan 7, 2004 | 11:58 PM
92 civic VX B18c's Avatar
HT Black Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">yeah, replace thermostat</TD></TR></TABLE> yep, fail safe thermostats rock!! I had the same problem
Old Jan 8, 2004 | 05:47 AM
Default Re: LOW Temp Reading (92 civic VX B18c)
Word up.....I got one from Autozone....is that bad.....should i go OEM? Autozone was the only thing open and it was so cheap.
Old Jan 8, 2004 | 09:53 AM
doublejz's Avatar
thermostats don't need to be oem, just make sure you stay around the stock temp, and don't forget to bleed it when your done or the problem will be opposite and you cant get your car to stay at half way temp
Old Jan 8, 2004 | 12:35 PM
Default Re: LOW Temp Reading (doublejz)
Thanks fellas..!
ice_nine_h95
Sep 19, 2006 07:48 PM
petersayarath
Jun 16, 2005 04:59 PM
fridexter
Dec 20, 2004 06:52 PM
pa2play
Aug 10, 2004 06:16 AM
length
Nov 20, 2003 07:39 AM
