WHAT IS BETTER VTEC SETTING FOR STOCK ITR?
Old Jan 7, 2004 | 09:53 PM
CTRbOy's Avatar
Default WHAT IS BETTER VTEC SETTING FOR STOCK ITR?
is 5000 or 5800 better for single vtec engagement on a stock ITR motor. someone please give me some info on which is better and why.
thanks
Old Jan 7, 2004 | 09:56 PM
o_Rage_o's Avatar
Default Re: WHAT IS BETTER VTEC SETTING FOR STOCK ITR? (itrboy)
on a stock itr, stock is usually best , Usually you have it moved up while doing dyno testing after a cam and/or gear install so that you can help smooth out your curve again when vtec engages
-rage
Old Jan 7, 2004 | 09:58 PM
CTRbOy's Avatar
Default Re: WHAT IS BETTER VTEC SETTING FOR STOCK ITR? (o_Rage_o)
i have an ITR motor in my eg also. someone is selling 2 same ecu's. one kicks in at 5 and one is at 5800. please help me decide before i make some kind of mistake
Old Jan 7, 2004 | 10:01 PM
RGoose18's Avatar
As o-rage already stated, the stock 5,800 vtec engagement is better for your application. If you didn't already know this, I dunno if you should be out rushing to buy an ECU.
Old Jan 7, 2004 | 10:17 PM
CTRbOy's Avatar
Default Re: WHAT IS BETTER VTEC SETTING FOR STOCK ITR? (RGoose18)
NO. i have an eg6 with an ITR swap in it. and i dont have an ecu for it yet. BECAUSE its obd1. unless you can make an obd1 p73. well i just want to know... if 5000 or 5800 is better for my choice of the ecu's right now. im just asking for help.
Old Jan 7, 2004 | 10:29 PM
b19coupe's Avatar
5800.
Old Jan 7, 2004 | 10:52 PM
RGoose18's Avatar
Default Re: WHAT IS BETTER VTEC SETTING FOR STOCK ITR? (b19coupe)
5,800
Old Jan 7, 2004 | 11:24 PM
Rdriver's Avatar
I wouldn't worry about the Vtec cross over as much as I would worry about the rev limit, If it is chipped ECU. My car is tuned and vtec Xover is at 5k.
Old Jan 8, 2004 | 03:11 AM
CTRbOy's Avatar
Default Re: WHAT IS BETTER VTEC SETTING FOR STOCK ITR? (Rdriver)
well its chipped and the rev limit is at 9600
Old Jan 8, 2004 | 04:35 AM
Euro98ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itrboy &raquo;</TD></TR><TR><TD CLASS="quote">well its chipped and the rev limit is at 9600</TD></TR></TABLE>
9600??? Thats too much man! Dont go more than 9100 on stock internals. Email Kenji : kenji211@tampabay.rr.com He is an expert on ecus!
Old Jan 8, 2004 | 04:54 AM
Willard's Avatar
I would ask your question in the hybrid forum.
Old Jan 8, 2004 | 05:54 AM
EEK's Avatar
EEK
Default Re: WHAT IS BETTER VTEC SETTING FOR STOCK ITR? (Euro98ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Euro98ITR &raquo;</TD></TR><TR><TD CLASS="quote">
someone was tellin me, his ecu's are based against the skunk program
Old Jan 8, 2004 | 06:24 AM
Jon D's Avatar
Yeah thats way too high for stock internals and your just going to end up making a bigger mistake then youd like too. 5800 and stock ecu if you have one.
Old Jan 8, 2004 | 10:33 AM
Black R's Avatar
25 Year Member
just fyi, stock itr vtec is at 5600... I dunno where this 5800 is coming from...
Most ppl find that lowering it a little to 5200 or so give more midrange and a smoother crossover (with simple bolt-ons that is).
cncl
Jun 17, 2010 05:58 AM
ITR_EGG
Apr 20, 2006 12:46 PM
aZnjCC
13
Nov 5, 2005 06:41 PM
dubnine
Mar 11, 2003 12:40 PM
