Are JE pistons stock in a 2000 B16A2?
Old Jan 7, 2004 | 08:40 PM
95IntegraGSRAZ's Avatar
Default Are JE pistons stock in a 2000 B16A2?
I am in the prosses of rebuilding my engine (B16A2).... I have it all apart and I was looking at the pistons and they say JE on them (it also says 81M on it). They have a dish like top to them.
I belive that JE makes aftermarket pistons....dose JE make pistons for hondas stock engines or is it possile that the person I got my swap from replaced the pistons (I had the engine imported from Japan)?
The rods say 5276.HO on them, and they have APR 2000 Bolts in them.
What do you think?
Any info would be great
Old Jan 7, 2004 | 08:43 PM
hondapro_2005's Avatar
Default Re: Are JE pistons stock in a 2000 B16A2? (civicvteckid)
pretty sure honda never used JE as oem. Kinda seems like a bonus,
Old Jan 7, 2004 | 09:04 PM
How do I figure out my Compression Ratio now? anyone know what kind they might be, I am trying find a pic but I am having no luck....
Old Jan 7, 2004 | 09:06 PM
V3locity's Avatar
lucky bitch
Old Jan 7, 2004 | 11:59 PM
degooser's Avatar
so how did the b16 feel any good? why u replacing the pistons?
Old Jan 8, 2004 | 12:02 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Are JE pistons stock in a 2000 B16A2? (degooser)
looks like you got some lower comp pistons yo
I have a guy looking for some actually.
Only way to find compression is this...find out the piston dome displacement...for those pistons it will be a negative number.
and then plug into a compression calculator
Old Jan 8, 2004 | 12:13 AM
Default Re: Are JE pistons stock in a 2000 B16A2? (Emerika)
I was planning on boosting the engine anyways so it couldnt have worked out any better... The pisonts look just like the ones I was going to buy.....I feel so special....
They look kinda like these, no markings on top tho....
Modified by civicvteckid at 9:26 AM 1/8/2004
Old Jan 8, 2004 | 12:53 AM
09civichatch[BRS]'s Avatar
http://www.bojangs.com/calculator/
B-series compression calculator
Old Jan 8, 2004 | 01:01 AM
b00sted93Hatch's Avatar
Default Re: Are JE pistons stock in a 2000 B16A2? (09civichatch)
With any info on the piston cc's he wont be able to calculate his compression. But being dished i'm guessing 9 flat? Maybe the motor was turbo'd before? Looks like you tore it apart when you didnt have to. Try to get some pictures so we can see what you have.
Old Jan 8, 2004 | 07:06 AM
Default Re: Are JE pistons stock in a 2000 B16A2? (allMotor93Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allMotor93Hatch &raquo;</TD></TR><TR><TD CLASS="quote"> Looks like you tore it apart when you didnt have to. </TD></TR></TABLE>
Your right, but I needed a winter project, plus I am sending the entire motor out to be acid cleaned. My swap actuly ended up be quite a good deal. The guy messed up my order the first time so I ended up getting the B16A2 (I was told it was out of an Si-R II), tranny, ecu, axels, shift linkages, all AC and all PS parts for $850 + $250 for shipping to my house so a total of $1100 . When I swaped the motor in and got it running it turned out that it had a blown head gasket, the company I bought the engine sent me $600 to have it fixed.
I am also putting in CTR cams and new springs and retainers in.
I have been searching JE Pistons and kinda firgured out that they are in the 8.5-9:1 area, which is perfect for my turbo setup that I was alredy planning on buying low commpression pistons for....
Old Jan 8, 2004 | 10:02 AM
What about the rods, they have 5276.HO printed on them and have 12 Point "APR 2000" bolts?
Old Jan 8, 2004 | 12:16 PM
ttt anyone?
Old Jan 8, 2004 | 04:19 PM
ttt for the evening
Old Jan 8, 2004 | 05:08 PM
sshaikh01's Avatar
if they have je pistons than woohoo for me
Old Jan 8, 2004 | 05:49 PM
Default Re: Are JE pistons stock in a 2000 B16A2? (sshaikh01)
I was very confused when I saw JE on the bottom of the pistons....
Old Jan 8, 2004 | 06:01 PM
Kidnkorner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicvteckid &raquo;</TD></TR><TR><TD CLASS="quote">so I ended up getting the B16A2 (I was told it was out of an Si-R II), </TD></TR></TABLE> if it said B16A2 on it it definatley didnt come out of any JDM car, for that matter its not even a JDM engine. no genuine JDM engine has any numbers in the 5th position ie B16A"2". your mad lucky all the way around, but my guess was the motor was a USDM engine rebuilt by someone in the states. i know it may sound wierd, and dumb, but why would someone in japan order pistons, and rods from the states when thier are a ton of othe JDM companies that make just as good stuff or better.
Vtec04
May 21, 2017 08:19 AM
8000+
Mar 14, 2004 07:48 AM
TheKidd
Sep 8, 2003 09:56 AM
fiaz79
Oct 31, 2002 09:18 AM
blkDOHCsol
Mar 24, 2002 01:30 AM
