Is fuel line that is slightly oversized bad?
Old Jan 7, 2004 | 04:28 PM
Jared's Avatar
Default Is fuel line that is slightly oversized bad?
I'm putting together the fuel system for my new sfwd car. I could go with 10an to the pump, then 8an up to the rail and 6an back, but because of some stuff I already have, it's gonna be cheaper to run all 10an and then 6an return. Is there any reason that being a little larger than I need will be bad?
thanks,
Jared
Old Jan 7, 2004 | 05:58 PM
D-Man's Avatar
Default Re: Is fuel line that is slightly oversized bad? (Jared)
only things that I can think of that would be bad....
1 Fittings more expensive
2 burst psi might be alittle lower
Old Jan 7, 2004 | 07:45 PM
Jared's Avatar
Default Re: Is fuel line that is slightly oversized bad? (D-Man)
That's about all I could come up with too. I guess I'm gonna go with the 10an all the way because I have all kinds of 10 an stuff already, save me a little money in the long run.
thanks,
Jared
Old Jan 7, 2004 | 08:02 PM
jinxproof99's Avatar
New User
i ran 10an out of my tank, to the fuel filter, to the pump, and to the fuel rails. fuel pressure gauge at the end of the fuel rail and 6an return to the tank. worked perfectly.
Old Jan 7, 2004 | 08:11 PM
RacerStev's Avatar
Only bad thing I can think of is the weight of the fuel in a large line is more. It
needs to work ageinst acceleration, the pump will need to work harder.
Steve
Old Jan 7, 2004 | 10:30 PM
Suprdave's Avatar
Default Re: Is fuel line that is slightly oversized bad? (RacerStev)
-10AN is baller ****...
Rikaro
Sep 25, 2009 11:36 PM
Matty.
28
Jul 30, 2006 08:54 PM
LBR92DA-T
Oct 25, 2003 02:21 AM
CRXBart
Jan 23, 2003 05:54 PM
