rear suspension rattles (searched...)
Old Jan 7, 2004 | 03:25 PM
OpTiX619's Avatar
Default rear suspension rattles (searched...)
i am running koni sports with neuspeed race in my ej6(ek) and there is rattling sounds coming from the rear suspension... i have checked pretty much everything but can not figure it out. when i have the shocks on fully tight i do not hear it as much... any ideas?
Old Jan 7, 2004 | 03:57 PM
tFUnK's Avatar
Default Re: rear suspension rattles (OpTiX619)
i dont know but mine rattles too. i'm riding stock ctr shocks/springs with rear strut bar and rear sway bar. the squeaks are from the bushings but i also hear a rattling sound. maybe the setup is stiff so other things in the trunk vibrate?
Old Jan 7, 2004 | 04:10 PM
OpTiX619's Avatar
Default Re: rear suspension rattles (tFUnK)
it seems that in the search that this question was asked several times but was never answered with assurance.. i had stock shocks in the car before and it did the same. however when i was running with coil overs, i did not have this problem...
Old Jan 8, 2004 | 11:57 AM
OpTiX619's Avatar
bump
Old Jan 8, 2004 | 11:59 AM
GTlvr82's Avatar
I have the exact same setup and it does the same friggin thing....would like to know as well.
Old Jan 8, 2004 | 01:03 PM
JICEK9's Avatar
Default Re: rear suspension rattles (GTlvr82)
I don't know if this is what your talking about, but... the ek have a problem with the rear trailing arm bushing making a clunking sound after the car has been lowered for a while. it happened to mine and my friends 00 coupes. solution=Mugen hard rubber bushing like I said before, I don't know if this is what your all refferring too.
btw-there is a service bulletin on it, but Honda just rplaces it with another bushing that WILL go bad again. it's a bitch to fix also.
Old Jan 8, 2004 | 01:39 PM
DJ_SaNdOz's Avatar
I've got the same issue w/ my EF & Neuspeed Race Springs. I have no clue what it is, I'll check the bushing out..........hopefully that fixes it, it's been like that forever now.
Old Jan 8, 2004 | 02:56 PM
OpTiX619's Avatar
Default Re: rear suspension rattles (DJ_SaNdOz)
does anyone have this problem using other springs? i will check the bushings...
Old Jan 8, 2004 | 03:12 PM
upgraded's Avatar
I am running Tokico HPs with RSR springs and ES bushing kit and every so Often I heard a *thud* sound or a knock come from the ***-end useually when I am pulling onto or off an apron (driveway) or going over speedbups. anyone have this, I have checked EVRYTHING and removed prts to check...nothing, I even removed the gastank and reinstalled with some rubber shims to see if it might be shifting side to side. Its anoying as hell any ideas? maybe a broken wled on one of the body seams? argg!!
Old Jan 8, 2004 | 03:13 PM
upgraded's Avatar
by the way, it did this BEFORE the bushing kit so don't go there...
Old Jan 8, 2004 | 03:16 PM
Ricey McRicerton's Avatar
Default Re: (upgraded)
Mine does the same **** with a stock suspension. It was much more noticeable with the back stripped out of the hatch. I would think it's the stock springs.
Old Jan 8, 2004 | 03:26 PM
OpTiX619's Avatar
r u running an aftermarket exhaust... my exhaust hits the underpart of my chassis making a thump when under hard turns or bumps...
Old Jan 8, 2004 | 03:28 PM
Default Re: (OpTiX619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OpTiX619 &raquo;</TD></TR><TR><TD CLASS="quote">r u running an aftermarket exhaust... my exhaust hits the underpart of my chassis making a thump when under hard turns or bumps...</TD></TR></TABLE>
I'm assuming you are asking me, and no, I'm still on my stock suspension. My exhaust has a HUGE canister (Apexi Dunk) and I have never once had it hit the underside of my hatchy.
Old Jan 8, 2004 | 03:31 PM
OpTiX619's Avatar
Default Re: (Ricey McRicerton)
sorry meant to ask 'upgraded' but still to lazy to figure out how to quote someone... i may be just the EJ's bushings.... what is the mileage on your 97?
Old Jan 9, 2004 | 05:26 AM
JICEK9's Avatar
if I knew how to post pics I could post the Honda Bullitin on the subject. It does it in my car before and after I had my JIC's. (before: progress sport springs/stock struts)
Old Jan 9, 2004 | 06:02 AM
Noe Kozz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Mine does the same **** with a stock suspension. It was much more noticeable with the back stripped out of the hatch. I would think it's the stock springs.</TD></TR></TABLE>
same thing with me, my rear is also stripped, man you here all types of noises back there
Old Jan 9, 2004 | 01:05 PM
OpTiX619's Avatar
Default Re: (Noe Kozz)
lets hear it for being gutted
my car came that way. bump
Old Jan 9, 2004 | 02:23 PM
pdiggitydogg's Avatar
have a rear sway bar?
id imagine its some interior part more than likely
Old Jan 9, 2004 | 04:19 PM
upgraded's Avatar
I still have a stock exaust on the car so I know thats not it. I'll figure it out one of these days. Thanks for the suggestions though.
Old Jan 9, 2004 | 04:24 PM
XxSOHCDriVerxX's Avatar
mine does it too, but only when its cold. makes a screeching noise.
jewpont
Suspension & Brakes
11
Feb 8, 2008 07:08 AM
caliek4
Apr 21, 2006 12:54 PM
Thirty-Nine
17
Jul 8, 2003 08:11 AM
kek-san
Jan 2, 2003 09:17 PM
