will a OBD I ecu work w/ an OBD 2 dizzy???
Old Jan 7, 2004 | 12:51 PM
SimbaDogg's Avatar
Default will a OBD I ecu work w/ an OBD 2 dizzy???
as the topic states...will a OBD I ecu work w/ an OBD 2 dizzy? i'm getting a brand new OBD 2 dizzy w/ my ITR head, and i just wanted to know if it would work cuz i'm gonna run a p30 ecu
Old Jan 7, 2004 | 01:22 PM
Malgerus's Avatar
Default Re: will a OBD I ecu work w/ an OBD 2 dizzy??? (SimbaDogg)
Yeah it should work.
My OBD-I P28 ran my OBD-II D16Y8 distributor with no problems.
Old Jan 7, 2004 | 05:44 PM
lilredhatch's Avatar
Oh yeah no prob. I got a 99 B18C1 in a 94 DX hatch using the 94 wiring harness. I just had to re-wire my dizzy with a obd1 connector so it would plug up.
Old Jan 7, 2004 | 05:48 PM
builthatch's Avatar
MiG-21 superfan
yes, it will work. I am running a y8 with a p30.
Old Jan 7, 2004 | 06:11 PM
SimbaDogg's Avatar
Default Re: will a OBD I ecu work w/ an OBD 2 dizzy??? (builthatch)
u just had to rewire the dizzy for the different connector? well, which connector is it...the one that goes from the harness into the dizzy? what exactly do you have to do to repin/rewire it? i dont have it infront of me so i can't really see the differences.
Old Jan 8, 2004 | 04:15 PM
u need to put an obd1 dizzy connector on your obd2 dizzy so it will plug in the obd1 harness. the 2 plugs are different but all wires are the same color
Old Jan 8, 2004 | 04:40 PM
dohcter g's Avatar
Default Re: will a OBD I ecu work w/ an OBD 2 dizzy??? (lilredhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilredhatch &raquo;</TD></TR><TR><TD CLASS="quote">u need to put an obd1 dizzy connector on your obd2 dizzy so it will plug in the obd1 harness. the 2 plugs are different but all wires are the same color</TD></TR></TABLE>
I could not have said it better!!!
Old Jan 8, 2004 | 09:35 PM
SimbaDogg's Avatar
Default Re: will a OBD I ecu work w/ an OBD 2 dizzy??? (dohcter g)
ok...here's the thing. i'm gonna run this dizzy in an EF chassis (OBD 0 wire harness). So how exactly should i wire it up? the OBD 2 plugs and the OBD 1 wireharness, its not that hard to rewire/repin it...but i have no idea how i'm gonna do it after looking @ my harness.
Old Jan 8, 2004 | 10:27 PM
MEANB18's Avatar
yep, I had to modify the wiring on my obd2 distributor to make it work with the P28 the car came with, but it will work. ('95 Civic with '00 B18C5)
Old Jan 10, 2004 | 08:17 AM
dohcter g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimbaDogg &raquo;</TD></TR><TR><TD CLASS="quote">ok...here's the thing. i'm gonna run this dizzy in an EF chassis (OBD 0 wire harness). So how exactly should i wire it up? the OBD 2 plugs and the OBD 1 wireharness, its not that hard to rewire/repin it...but i have no idea how i'm gonna do it after looking @ my harness. </TD></TR></TABLE>
Cut off the plug matching your dizzy ( OBD I or OBD II) Then using but splicing and heat shrink match colors. The OBD 0 is a little diff in color seq. so follow the wires to see where they go on the distributor and mark them before cutting. Good Luck!!
The alternator and fuel injectors will have to be done also!
SPOON_BeIgHtEeNsEe
Aug 1, 2006 07:59 AM
Dark91zc
Jun 9, 2005 03:40 PM
groundedcivic91
Jan 19, 2005 09:33 PM
SimbaDogg
Jan 22, 2004 02:47 PM
SimbaDogg
Jan 7, 2004 02:10 PM
