Type-R hybrid or GSR Hybrid??
I currently have a 92 hatch with a 94 JDM GSR motor in it. I currently have the opportunity to trade in my current swap, plus $2300 CDN (equivalent to $1400 USD) for a type-R swap. This includes the R tranny and ECU. Do you think i should go for this or should i spend the money building the current motor? Any info would be great!
BTW, the motor is not hot, just so happens that the shop is looking for a GSR motor...REALLY BAD!!!
They are both great engines. you have to ask yourself if 20 more HP is worth $1,400. The LSD in the Type R trans sweetns the deal considerably. If the price you quoted includes the work to swap the motors then I'd say go for it.
Mike
Mike
Go for it...sounds like a good deal. It would take more than $1400 to get your gsr motor/tranny to perform as well as a stock type r setup. remember that the type r motor is obd2 so you would want to keep your gsr distributor and you'll have to get an obd1 ecu.
I think i am getting the type R ECU and the distributor......would this be bad?? Actually, i can get a JDU type-R ECU, which from what i heard is OBD1 in exchange for my USDM OBD2 P73 ECU.....should i do this? Would this make my install easier?
[Modified by eg-six, 5:49 AM 9/28/2001]
You'd need to get a jumper in order for you to run the ITR ecu in your car. Although they are set up with OBD 1 programs, the plugs are still made for an OBD 2 car. You could always retain your stock GSR computer and get it reprogrammed or find a cheap P28 somewhere. There are a bunch of options.
i was thinking like evo on how you should drop off your head at portflow and get that built. But for $1400 including labor for a type r motor you can beat that. Just make sure everything is legit. You don't want to be stuck w/ a type r motor w/ a b16 head.
Depends on the milage of the Type R compared to the milage on your GSR.
I traded my GSR swap with 70k+ miles for jdm Type R swap with only 10kmiles. So the extra $$ it costed was worth it since i got a lot lower milage motor.
I would say go with the ITR motor. If you stick with the ITR motor you wil never say "what if I kept the GSR motor?"' But if you don't get it the thought will always be in the back of your head "what if I went with the ITR motor?"
R components for the difference??hmm lets see here.. for the 1200 he pays hes gets
jdm itr tranny with lsd and final drive
bigger TB
better intake manifold
pistons
rods
valvetrain
cams
head
crank
etc...hmm u think thats worth 1200???besides the fact that the tranny alone is 1200-2000...............
bigger TB
pistons
rods
valvetrain
cams
head
crank
i'd say stick w/ the gsr, build up your motor cams, ect... you have a good motor and for 20 hp. is it worth it think about that for a min... its up to you but if anything i would def. say get a lsd you wont be sorry on that part...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG »</TD></TR><TR><TD CLASS="quote">R components for the difference??hmm lets see here.. for the 1200 he pays hes gets
bigger TB
pistons
rods
valvetrain
cams
head
crank
etc...hmm u think thats worth 1200???besides the fact that the tranny alone is 1200-2000...............</TD></TR></TABLE>
yeah thats exactly why I went that route. plus youre getting an engine that was put together at the factory.
bigger TB
pistons
rods
valvetrain
cams
head
crank
risiah05
21
Feb 12, 2004 04:08 PM
Prod
Oct 30, 2002 04:59 AM
