want a bit more power, what to do?
Old Jan 6, 2004 | 11:37 PM
r7's Avatar
r7
Default want a bit more power, what to do?
don't want to build motor.. what can i add to make a bit more power?
i was thinking gsr cams and exhaust cut out.. what else?
Old Jan 7, 2004 | 01:15 AM
beerbongskickass's Avatar
Default Re: want a bit more power, what to do? (r7)
If your sig is correct and your only running 7 psi then turn up the boost if you want more power. What are you running for fuel management?
Old Jan 7, 2004 | 02:02 AM
EG6chick's Avatar
forget more power, you need to get it to the ground or something.. a 13.4 at 107?? thats a good amount of power, you should be getting quicker e.t's.. good suspension and tires/slicks should help a lot...
Old Jan 7, 2004 | 04:16 AM
BoostedsiR's Avatar
Default Re: want a bit more power, what to do? (EG6chick)
yeah turn up the boost and maybe a 3 inch dp and exhaust, but a 2.2 60 ft I use to do that in my n/a b16 you must be spinning a lot get slicks and then dump it you should cut that 60 ft down to 1.9 maybe 1.8
Old Jan 11, 2004 | 02:05 PM
r7's Avatar
r7
Default Re: want a bit more power, what to do? (BoostedsiR)
thanks for the replys.. so
fix alignments, mainly camber
13", with 24.5" slicks
exaust cut out
sound good? =o
SIsamson22
35
May 9, 2010 12:20 AM
1sicef9
Dec 1, 2009 07:21 AM
J-Spec EG
Dec 4, 2004 11:24 PM
cool
Mar 25, 2003 04:28 PM
