Aeromotive FPR + Stock Fuel Rail - Can I use a fitting like this.....
I need to connect a hose to the fuel rail at the location of the stock FPR.
Does anyone know if I can use something like this? For a -6 AN hose. I just need to be able to thread something on there, I can use reducers/adapters after that.
Modified by slashDEVslashNULL at 9:19 PM 1/6/2004
I haven't seen any flanges that adapt to what you are looking for. your best bet might be to pull off the stock fpr and tap the middle hole 1/8"NPT. I've done this before and it worked fine. Requires a little bigger drillbit to get the tap to go in there but it does work. then just get a 1/8"NPT > -6AN and you're set. Let me know if you don't have the tools, I can do one up real quick for ya, I have extra rails laying around and a drill press and tap handy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenoRacing »</TD></TR><TR><TD CLASS="quote">I haven't seen any flanges that adapt to what you are looking for. your best bet might be to pull off the stock fpr and tap the middle hole 1/8"NPT. I've done this before and it worked fine. Requires a little bigger drillbit to get the tap to go in there but it does work. then just get a 1/8"NPT > -6AN and you're set. Let me know if you don't have the tools, I can do one up real quick for ya, I have extra rails laying around and a drill press and tap handy.
Is there enough material on there to tap it? I don't remember exactly, but it looked pretty thin.
EDIT: What size drill bit do you use?
How much do you want for one of your rails already tapped? Wouldn't hurt to have an extra rail.
Modified by slashDEVslashNULL at 9:26 PM 1/6/2004
</TD></TR></TABLE>Is there enough material on there to tap it? I don't remember exactly, but it looked pretty thin.
**** man, $10 outta cover shipping and the paypal nonsense. I can go out and fix it up for ya rightnow if you'd like a picture or something. give me a minute.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenoRacing »</TD></TR><TR><TD CLASS="quote">**** man, $10 outta cover shipping and the paypal nonsense. I can go out and fix it up for ya rightnow if you'd like a picture or something. give me a minute.
Thanks a lot man
If you give me your paypal I'll send you $10 tomorrow. I really appreciate this.
</TD></TR></TABLE>Thanks a lot man
No problem man, that's what honda-techs all about. what's your addy?
Just to make sure, B series right?! I totally forgot to ask.
havokmob@yahoo.com I thought I had one of the fittings for ya too but I don't with -6an, only -4an and -8an.
one of these and you're set. or maybe a 90° to be safe but I think you got tons of room.
http://store.summitracing.com/...81662
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenoRacing »</TD></TR><TR><TD CLASS="quote">No problem man, that's what honda-techs all about. what's your addy?
one of these and you're set. or maybe a 90�??�?�° to be safe but I think you got tons of room.
Thanks a lot! I will paypal you tomorrow and email you my address, I can't tell you how much I appreciate this
Oh yeah, it is b series.
5/16" drill bit to tap 1/8NPT
</TD></TR></TABLE>5/16" drill bit to tap 1/8NPT
Cool man, I'll head down to the post office in a bit and ship it out to you, most likely priority if its under $6 or so.
Just want to make sure, that this is the address you want it sent to right?
**** Brighton Cove.
**** Brighton Cove.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenoRacing »</TD></TR><TR><TD CLASS="quote">Cool man, I'll head down to the post office in a bit and ship it out to you, most likely priority if its under $6 or so.
**** Brighton Cove.</TD></TR></TABLE>
yeah , thanks.
yeah , thanks.
Seen that done before...Looks great!!! Who needs the stock dinky FPR anyways...??!!
</TD></TR></TABLE>Seen that done before...Looks great!!! Who needs the stock dinky FPR anyways...??!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo »</TD></TR><TR><TD CLASS="quote">
Who needs the stock dinky FPR anyways...??!!</TD></TR></TABLE>
Who ever wants to save money and those who do not need to adjust their fuel pressure.
He ended up just using a stock rail and then tapped the fpr port w/ a 1/8"npt tap and then thread in a -4 or -6an fitting and run it to an external mounted regulator like the aeromotive.
why not a rail mounted Aeromotive FPR???????
EDIT: changed the address, one "freespace" server is down for maintainance.
Modified by Mista Bone at 3:12 PM 2/7/2004
mista bone - i see red x's on the pic of the rail mount fpr. do u have a aeromotive part# or a link to it or something? im about to upgrade the fuel rail, fpr, lines, etc... any help is greatly appreciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">why not a rail mounted Aeromotive FPR???????
This is exactly what I'm doing...only with a GE fuel rail
It is not my thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">
Same here
On a different note, how do this one differ from the one in the other pic above?
</TD></TR></TABLE>Same here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVATAR »</TD></TR><TR><TD CLASS="quote">
Same here
On a different note, how do this one differ from the one in the other pic above?</TD></TR></TABLE>
this is the setup i wont
Same here
JM Performance
Apr 17, 2005 04:21 PM
B18EG6
Jan 8, 2003 12:24 AM
lucas569
May 14, 2002 10:05 AM
