Aeromotive FPR + Stock Fuel Rail - Can I use a fitting like this.....
I need to connect a hose to the fuel rail at the location of the stock FPR.
Does anyone know if I can use something like this? For a -6 AN hose. I just need to be able to thread something on there, I can use reducers/adapters after that.
Modified by slashDEVslashNULL at 9:19 PM 1/6/2004
Re: Aeromotive FPR + Stock Fuel Rail - Can I use a fitting like this..... (slashDEVslashNULL)
I haven't seen any flanges that adapt to what you are looking for. your best bet might be to pull off the stock fpr and tap the middle hole 1/8"NPT. I've done this before and it worked fine. Requires a little bigger drillbit to get the tap to go in there but it does work. then just get a 1/8"NPT > -6AN and you're set. Let me know if you don't have the tools, I can do one up real quick for ya, I have extra rails laying around and a drill press and tap handy.
Re: Aeromotive FPR + Stock Fuel Rail - Can I use a fitting like this..... (RenoRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenoRacing »</TD></TR><TR><TD CLASS="quote">I haven't seen any flanges that adapt to what you are looking for. your best bet might be to pull off the stock fpr and tap the middle hole 1/8"NPT. I've done this before and it worked fine. Requires a little bigger drillbit to get the tap to go in there but it does work. then just get a 1/8"NPT > -6AN and you're set. Let me know if you don't have the tools, I can do one up real quick for ya, I have extra rails laying around and a drill press and tap handy. </TD></TR></TABLE>
Is there enough material on there to tap it? I don't remember exactly, but it looked pretty thin.
EDIT: What size drill bit do you use?
How much do you want for one of your rails already tapped? Wouldn't hurt to have an extra rail.
Modified by slashDEVslashNULL at 9:26 PM 1/6/2004
**** man, $10 outta cover shipping and the paypal nonsense. I can go out and fix it up for ya rightnow if you'd like a picture or something. give me a minute.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenoRacing »</TD></TR><TR><TD CLASS="quote">**** man, $10 outta cover shipping and the paypal nonsense. I can go out and fix it up for ya rightnow if you'd like a picture or something. give me a minute. </TD></TR></TABLE>
Thanks a lot man
If you give me your paypal I'll send you $10 tomorrow. I really appreciate this.
Thanks a lot man
No problem man, that's what honda-techs all about. what's your addy?
Just to make sure, B series right?! I totally forgot to ask.
havokmob@yahoo.com I thought I had one of the fittings for ya too but I don't with -6an, only -4an and -8an.
one of these and you're set. or maybe a 90° to be safe but I think you got tons of room.
http://store.summitracing.com/...81662
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenoRacing »</TD></TR><TR><TD CLASS="quote">No problem man, that's what honda-techs all about. what's your addy?
one of these and you're set. or maybe a 90�??�?�° to be safe but I think you got tons of room.
Thanks a lot! I will paypal you tomorrow and email you my address, I can't tell you how much I appreciate this
Oh yeah, it is b series.
5/16" drill bit to tap 1/8NPT
Cool man, I'll head down to the post office in a bit and ship it out to you, most likely priority if its under $6 or so.
Just want to make sure, that this is the address you want it sent to right?
**** Brighton Cove.
**** Brighton Cove.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RenoRacing »</TD></TR><TR><TD CLASS="quote">Cool man, I'll head down to the post office in a bit and ship it out to you, most likely priority if its under $6 or so.
**** Brighton Cove.</TD></TR></TABLE>
yeah , thanks.
yeah , thanks.
O.G. triple O.G.
Seen that done before...Looks great!!! Who needs the stock dinky FPR anyways...??!!
Re: Aeromotive FPR + Stock Fuel Rail - Can I use a fitting like this..... (NVturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo »</TD></TR><TR><TD CLASS="quote">
Who needs the stock dinky FPR anyways...??!!</TD></TR></TABLE>
Who ever wants to save money and those who do not need to adjust their fuel pressure.
where do you get these stock fuel pressure regulator to an adapter fittings?
Re: Aeromotive FPR + Stock Fuel Rail - Can I use a fitting like this..... (turbogeekDA6)
He ended up just using a stock rail and then tapped the fpr port w/ a 1/8"npt tap and then thread in a -4 or -6an fitting and run it to an external mounted regulator like the aeromotive.
D Tranny Guru
why not a rail mounted Aeromotive FPR???????
EDIT: changed the address, one "freespace" server is down for maintainance.
Modified by Mista Bone at 3:12 PM 2/7/2004
Re: Aeromotive FPR + Stock Fuel Rail - Can I use a fitting like this..... (Mista Bone)
mista bone - i see red x's on the pic of the rail mount fpr. do u have a aeromotive part# or a link to it or something? im about to upgrade the fuel rail, fpr, lines, etc... any help is greatly appreciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">why not a rail mounted Aeromotive FPR???????
This is exactly what I'm doing...only with a GE fuel rail
It is not my thing.
Re: Aeromotive FPR + Stock Fuel Rail - Can I use a fitting like this..... (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">
This is exactly what I'm doing...only with a GE fuel rail </TD></TR></TABLE>
Same here
On a different note, how do this one differ from the one in the other pic above?
Same here
Re: Aeromotive FPR + Stock Fuel Rail - Can I use a fitting like this..... (AVATAR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVATAR »</TD></TR><TR><TD CLASS="quote">
Same here
On a different note, how do this one differ from the one in the other pic above?</TD></TR></TABLE>
this is the setup i wont
Same here
JM Performance
04-17-2005 04:21 PM
B18EG6
01-08-2003 12:24 AM
lucas569
05-14-2002 10:05 AM
