Tach & Speedo calibration off on my '97?
Old Jan 6, 2004 | 06:42 PM
Utilitarian's Avatar
Default Tach & Speedo calibration off on my '97?
I was wondering if anyone knew if there was a correlation between a miscalibrated tach and speedometer. The answer may be obvious, but the reason I ask is that the vtec begins at 6K which is fairly high. That's a matter that has been beaten into the ground, I know, but the speedo may be high too. My friend rode down to Wilmington with me a couple of weeks ago to get the R and drove it back following me in the GST (I was going to drive the R back, but the GST had bad plugs & wires so it started missing like crazy so I navigated it back). Anyway, I set the cruise on 80 and my friend followed closely in the R. When we stopped he told me that I was going 85, easily. I know vtec is activated by oil pressure and may be different on all cars, by the two factors together get me thinking. Has anyone experienced this and how can I test to see if it's off.
Old Jan 6, 2004 | 06:57 PM
Champ R's Avatar
Default Re: Tach & Speedo calibration off on my '97? (Stock97ITR#50)
The stock tach's known for being a few hundred rpm off... with my stock ecu, vtec engages at an indicated 5900-6000rpm if you watch closely.
Old Jan 6, 2004 | 07:02 PM
Default Re: Tach & Speedo calibration off on my '97? (Champ R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Champ R &raquo;</TD></TR><TR><TD CLASS="quote">The stock tach's known for being a few hundred rpm off... with my stock ecu, vtec engages at an indicated 5900-6000rpm if you watch closely. </TD></TR></TABLE>
That's what I've heard. I kind of wish they set it lower from the factory. VAFC may be in my future.
Old Jan 6, 2004 | 07:10 PM
Ill's Avatar
Ill
There is no correllation. Tach is electronic, speedo is mechanical. I think it's just a coincidence. They are both off a little, and about the same amount.
96hatchBoy
Jun 8, 2013 02:31 PM
eg8b18
Mar 20, 2012 02:03 PM
euclid
Aug 3, 2003 11:29 AM
JDM 007
May 27, 2002 02:02 PM
JDM R98
Aug 3, 2001 04:57 AM
