EF Trailing Arms and the DA discs...
Old Jan 6, 2004 | 12:33 PM
JDMHN8's Avatar
Default EF Trailing Arms and the DA discs...
Well, I know the DA arms bolt up to the EF and vice versa. My question is, can you just swap the brake assembly from the DA onto an EF drum arm?
I want to use an unmodified Mugen TA bushing, and I'd rather not blow the money on DC2 TAs for no reason other than the smaller diameter TA bushing. If any of you guys can help me out here, I would greatly appreciate it.
Even if you have some drum TAs that you want to sell, that would be helpful as well....
Old Jan 6, 2004 | 01:00 PM
EL Vap133's Avatar
Default Re: EF Trailing Arms and the DA discs... (JDMDA9)
Hmm, I am not sure if it is possible. I think if you buy the conversion part by part, it will be more expensive in the long run.
Old Jan 6, 2004 | 01:46 PM
ninjaMONKEY
Guest
Posts: n/a
Default Re: EF Trailing Arms and the DA discs... (EL Vap133)
from what i remebered, from when i did the rear conversion (using all DA equip.) there are several key diffrences mainly in how the spindles mount to the TA. Also the way the brake lines are ran, i believe they are part of the trailing arm itself at one point. Hope it might help you out some. If you can get some DA spindles first and try it out of you need the TA them buy them. I get most of my junked stuff from honda/acura palace in 626.
good luck
Old Jan 6, 2004 | 02:10 PM
MestizoRacer310's Avatar
Default Re: EF Trailing Arms and the DA discs... (ninjaMONKEY)
wut's the number to honda/acura palace? i can't find it on yahoo yellow pages....
Old Jan 6, 2004 | 02:54 PM
JDMHN8's Avatar
Default Re: EF Trailing Arms and the DA discs... (MestizoRacer310)
Ok, sounds like this isn't going to be possible. But to clarify, I just want to transfer all the brake components off of the trailing arms on my DA right now to an easy to find EF trailing arm.
But if the spindles don't bolt up properly, then it just won't work. But thank you for the help so far, guys.
Anyone have some pics of Civic TAs?
Old Jan 6, 2004 | 03:33 PM
Doctor CorteZ's Avatar
use 94-up rear disc stuff , it doesnt have the larger bushings that the DA does.
Old Jan 6, 2004 | 05:03 PM
ninjaMONKEY
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MestizoRacer310 &raquo;</TD></TR><TR><TD CLASS="quote">wut's the number to honda/acura palace? i can't find it on yahoo yellow pages....</TD></TR></TABLE>
Hondacura Palace (323) 357-9999
1848 E 55th St, Los Angeles, CA 90058
sorry its 323 not 626
Old Jan 6, 2004 | 05:22 PM
rags2riches's Avatar
DA trailing arms work, so do EG's ... I have a set of EG arms on my 90 hatch, and my buddy has the the DA arms on his 91 ...
Old Jan 6, 2004 | 05:24 PM
btw, all trailing arms are same stamp or casting , its just slight slight differences in the spindle that makes the different # of the complete arm... nothing too different that would not allow you to use them.
Old Jan 6, 2004 | 06:23 PM
Default Re: (rags2riches)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rags2riches &raquo;</TD></TR><TR><TD CLASS="quote">btw, all trailing arms are same stamp or casting , its just slight slight differences in the spindle that makes the different # of the complete arm... nothing too different that would not allow you to use them.</TD></TR></TABLE>
NOPE.
try again , the DA is the only one to make use of the larger compensator arm bushing. ALL the rest are the same , not the DA though.
Old Jan 6, 2004 | 06:47 PM
JDMHN8's Avatar
Default Re: (Doctor CorteZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ &raquo;</TD></TR><TR><TD CLASS="quote">
NOPE.
try again , the DA is the only one to make use of the larger trailing arm bushing. ALL the rest are the same, not the DA though.</TD></TR></TABLE>
Exactly.
Well, it was worth asking. Guess I'll just use the DC2 arms...
Old Jan 6, 2004 | 07:02 PM
I thought you meant the trailing arm bushing, the TRAILING arm it self is EXACTLY THE SAME THOUGH, im not talking about upper/lower arms just the trailing arm itself.
Old Jan 6, 2004 | 09:23 PM
JDMHN8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rags2riches &raquo;</TD></TR><TR><TD CLASS="quote">I thought you meant the trailing arm bushing, the TRAILING arm it self is EXACTLY THE SAME THOUGH, im not talking about upper/lower arms just the trailing arm itself. </TD></TR></TABLE>
No it's not. The DA has a larger diameter hole for the TA bushing. The EF/DC/EG TAs have a smaller diameter hole for the TA bushing. Thus, the arms are not the same. The diffrence is not just the bushing, but the entire arm. You cannot use the Mugen TA bushing in the DA arm off the shelf because it is too small.
Old Jan 7, 2004 | 11:50 AM
purple haze's Avatar
jdma9, the bushing is different and so is the pin, but the arm isnt.
Old Jan 7, 2004 | 12:28 PM
Default Re: (purple haze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purple haze &raquo;</TD></TR><TR><TD CLASS="quote">jdma9, the bushing is different and so is the pin, but the arm isnt.</TD></TR></TABLE>
please enlighten me , how do you fit a different sized bushing into the same hole ?
Old Jan 8, 2004 | 01:01 AM
JDMHN8's Avatar
Anyone else have something to add that we my have missed. I can pick up a set of EF TAs for dirt cheap...
ziurek filmus
May 14, 2017 07:29 AM
Creator
Jul 21, 2010 05:42 PM
Charlie Moua
Sep 30, 2009 02:36 PM
b16box
Suspension & Brakes
Feb 11, 2006 08:01 PM
1JDMDOMINICAN
Sep 29, 2005 06:54 AM
