DA trailing arm the same as EF's?
$cat /dev/urandom
Re: DA trailing arm the same as EF's?
yeah, effectively it is. in order to do the RTA swap, you need to use the EF "toe arms" and not the DA's. The ebrake cable from the EF is the one you want to use too, the DA one won't work.
In truth I've already done the left side with a DA trailing arm for the disk conversion. Upon working on the right side I discovered the trailing arm I have from the DA is damaged, where the LCA bolts up. I did notice some minor differences in the trailing arms, small holes that don't get used.
Obviously measuring both trailing arms from specific points would show whether the mounting points are the same. I was just hoping someone had already done this.
yes i have had DA arms on my both my crx's and both my hatch's they fit and work just fine i also have just replaced the hub in the rear as well if you don feel same only haveing one DA and on EF just replace the hubs
i had pressed in new bushings.
DA ones are diffrent to EF civic
DA is larger inside. EF is a smaller dog bone like thing. I purchased EF civic rear bushings for the arms and when i got them it was diffrent Realised it wasfor a DA. I got it all worked out and breaks on but i need to get the pedal strait with either a booster/master cylinder
so im confused are people talking about doing rear disc conversion because thats what i wanna do but im not sure if it bults up i just picked up a set from 90 DA with every little bolt... any help is good thanks
it bolts up, but its not the same as a crx trailing arm.
if you are going to replace the trailing arm bushing, then get a teg replacement. or do what wes did. RIP
http://www.performanceforum.com/wesv...g/bushing.html
exgr
23
08-26-2011 02:09 PM
JDMHN8
15
01-08-2004 01:01 AM
