drum-to-disc conversion help
Old Jan 6, 2004 | 11:24 AM
boosted2point2ek's Avatar
Default drum-to-disc conversion help
will the disc's off an 90-93 integra work for my 94 civic...and how would i run the setup??
Old Jan 6, 2004 | 11:39 AM
2manycars2choose's Avatar
Default Re: drum-to-disc conversion help (ghettocivic94)
There is a huge thread on brakes. Maybe a search..... ?
Old Jan 6, 2004 | 11:45 AM
Default Re: drum-to-disc conversion help (2manycars2choose)
sweet...thanks...but i did the search and it did not come up with much...any other help??
Old Jan 6, 2004 | 12:00 PM
pdiggitydogg's Avatar
there was even a topic on this last week
No, wont work
you need 94+ integra, del sol s/si, civic si (hatch (92-95 and coupe 99-00)
Old Jan 6, 2004 | 12:02 PM
Default Re: (pdiggitydogg)
darn....had the parts for free...well will try something else...maybe try to find some off of one that will fit
Old Jan 23, 2004 | 07:56 AM
SpeedDreamz.com's Avatar
Why dont you come down here and get the correct answer?
Old Jan 23, 2004 | 08:55 AM
Syncmaster's Avatar
I also think crx si rear disc brakes will work too...correct me if Im wrong. If they do, Im willing to be they could be had for very cheap.
Old Jan 23, 2004 | 08:56 AM
owen_the_soyboy's Avatar
Default Re: (ghettocivic94)
sure they'll fit.
dang. who gave up the wrong info?!
YES THEY WILL FIT.
of course it depends on how many parts you plan on swapping. you can swap just the rear hubs or the entire trailing arms, whichever you consider easier.
Old Jan 23, 2004 | 08:58 AM
redlinetuning's Avatar
Default Re: drum-to-disc conversion help (70hpHatch)
No.. the DA parts will not work into an EG, DC, nor EK. Only EFs and DA's are interchangeable.
Old Jan 23, 2004 | 09:01 AM
fcuked's Avatar
Yes they will work, you can put DA rears on an EG. Only problem i have with that is the fact that the parts just too old (worn bushings).
Old Jan 23, 2004 | 09:03 AM
Default Re: drum-to-disc conversion help (redlinetuning)
wtf...i posted this like more than 2 weeks ago...reviving the dead arent we tracey
Old Jan 23, 2004 | 09:04 AM
DIY_Racing's Avatar
Hey, i have a set of gsr rear brakes. 97.. EVERYTHING included.. New pads also.
Just lettin ya know.
Old Jan 23, 2004 | 12:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinetuning &raquo;</TD></TR><TR><TD CLASS="quote">No.. the DA parts will not work into an EG, DC, nor EK. Only EFs and DA's are interchangeable. </TD></TR></TABLE> dude, I think you are wrong. Also, you better specify what parts you are taling about if you think they do NOT interchange. Of course the DA/EF rear disc swap is usable on EG's, DC's and EK's, but the other suspension parts (lca's, uca's, front knuckles, etc...) are NOT.
Old Jan 23, 2004 | 12:42 PM
TeamNextGenChris's Avatar
I just put a DA rear disc conversion on an EK a couple months ago.it DOEs work.of course,it will fit an EG also.
chris
Old Jan 23, 2004 | 12:57 PM
hondahans's Avatar
Default Re: drum-to-disc conversion help (owen_the_soyboy)
The DA brakes will 100% work on an EG... Or any other Honda til .00. We put a set of 91 GS rear discs on a friends 94 hatch and it was a direct swap. We kept his control arms, as well as the Toe link on the trailing arm. The trailing arms are the same dimension, its just other parts (mentioned) that have subtle differences.
ghettocivic94, go ahead and swap them. You will see first hand how easy and direct it is.
Old Jan 23, 2004 | 02:46 PM
Default Re: drum-to-disc conversion help (hondahans)
well...i guess i have a weekend project...all i have to do now is go and get some new brake lines ...anything else i would need...maybe new pads too
Old Jan 23, 2004 | 02:52 PM
FifthGearOnline's Avatar
this is the huge brake thread we have going
https://honda-tech.com/zerothread?id=152884
Old Jan 23, 2004 | 07:36 PM
idumpwitmy12gaugepump's Avatar
Default Re: (FifthGearOnline)
i got a 95 si. it comes with rear disc brakes.
racerx510
Jul 27, 2010 01:35 PM
r0guish
Mar 31, 2005 09:59 PM
Mike K
11
Feb 23, 2005 07:32 AM
ZzZzz EH2
Apr 22, 2004 10:45 PM
B18C2_sedan
35
Jun 3, 2003 09:32 AM
