mods after installing an edelbrock turbo kit
Old Jan 6, 2004 | 08:15 AM
Dasani's Avatar
Default mods after installing an edelbrock turbo kit
When reading about the kit, I noticed that it will perform great on my stock d16y8 motor, but what if i wanted to do other modifications (i.e. skunk2 intake manifold, pistons (a1), camshafts, etc. What would I have to do to the turbo to make my car perform to its top potential...
I'm new to the turbo scene so is there a way to increase the psi without blowing the motor and with just pump gas....Thanks in advance
Old Jan 6, 2004 | 08:43 AM
CarbonCreations's Avatar
Default Re: mods after installing an edelbrock turbo kit (Dasani)
ah i see why youre at 95%.
because you dont search.
all of these topics have been covered many many times. look up "custom turbo" and go to the webpage "homemadeturbo.com"
Old Jan 6, 2004 | 08:46 AM
SOHC_MShue's Avatar
read read read the FI forum
Old Jan 6, 2004 | 08:56 AM
paradise57's Avatar
Default Re: mods after installing an edelbrock turbo kit (SOHC_MShue)
Not to mention the Edelbrock comes WITH a new intake manifold, making the purchase of a skunk2 manifold an unnecessary and near-useless expense.....
96hb's Avatar
Default Re: mods after installing an edelbrock turbo kit (CarbonCreations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarbonCreations &raquo;</TD></TR><TR><TD CLASS="quote">ah i see why youre at 95%.
So, why are you at 96%? You could also check out turbod16.com. There is some nice info there as well.
Old Jan 6, 2004 | 09:00 AM
SOHC_MShue's Avatar
Default Re: mods after installing an edelbrock turbo kit (paradise57)
yea the edelbrock manifold is definantely nice
Old Jan 6, 2004 | 01:01 PM
Aquafina's Avatar
EDelbrock turbo kit comes with an IM. A1 pistons = 12.6:1 = too high for F/I. D16Y8 = SOHC. You can still get any kind of parts you want to.
Have the block resleeved, forged rods, forged pistons, bigger turbo, cam, EMS, etc.
Yes there is, just turn the boost up. Get it resleeved and some rods and it won't blow unless you get stupid with it.
Old Jan 6, 2004 | 01:07 PM
Adam.'s Avatar
all of these topics have been covered many many times. look up "custom turbo" and go to the webpage "homemadeturbo.com"</TD></TR></TABLE>
ah I see why you're at 96%.
because you are a schmuck.
And as far as raising psi without using more than pump gas I believe you must lower your compression.
Old Jan 7, 2004 | 07:37 AM
Dasani's Avatar
Sorry I didn't search for "custom turbo," but i did search before posting this thread, and the only reason i'm at 95% is that someone got on my username and messed some things up. Probably a much better reason then why your at 96.
Old Jan 7, 2004 | 04:54 PM
Aquafina's Avatar
Kinder kinder, nicht so gut! Remember what I said Shane. Faster now or slower later.
Old Jan 7, 2004 | 05:00 PM
kommon_sense's Avatar
Default Re: mods after installing an edelbrock turbo kit (Aquafina)
dasani and aquafina... I am easily amused
Old Jan 7, 2004 | 05:51 PM
Aquafina's Avatar
Default Re: mods after installing an edelbrock turbo kit (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense &raquo;</TD></TR><TR><TD CLASS="quote">dasani and aquafina... I am easily amused </TD></TR></TABLE>
Cookie?
Old Jan 8, 2004 | 07:43 AM
Dasani's Avatar
There's still evian, deerpark, brita, and john boy and billy authentic mountain spring water!
Old Jan 8, 2004 | 07:48 AM
elevatethis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">EDelbrock turbo kit comes with an IM. A1 pistons = 12.6:1 = too high for F/I. D16Y8 = SOHC. You can still get any kind of parts you want to.
Yes there is, just turn the boost up. Get it resleeved and some rods and it won't blow unless you get stupid with it.</TD></TR></TABLE>
I'd say that most boosted motors that blow fail when the wristpins call it quits. Strong rods and a larger intercooler are a MUST when looking to increase boost. Fuel management is also important when higher boost is used, or else a lean mixture will result and then you can kiss your motor goodbye.
Old Jan 8, 2004 | 07:58 AM
opi's Avatar
opi
yep, the edelbrock kit is pretty complete already. as aquafina mentioned, you might want to turn your attention to the block, pistons/rods/sleeves... . upgrade the internals of your block, fortify it to take more boost...good luck
Old Jan 8, 2004 | 01:50 PM
snoochtodanooch's Avatar
Default Re: mods after installing an edelbrock turbo kit (elevatethis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elevatethis &raquo;</TD></TR><TR><TD CLASS="quote">
I'd say that most boosted motors that blow fail when the wristpins call it quits. Strong rods and a larger intercooler are a MUST when looking to increase boost. Fuel management is also important when higher boost is used, or else a lean mixture will result and then you can kiss your motor goodbye.</TD></TR></TABLE>
Retarding also helps mucho
Old Jan 8, 2004 | 02:30 PM
Marauder's Avatar
Default Re: mods after installing an edelbrock turbo kit (snoochtodanooch)
You can run about 10-11 psi on the stock Y8. Just add a boost controller, and there are two different tuning devices to tune the Edelbrock piggyback to adjust fuel and timing. Either a serial cable to a laptop, or a handheld controller, from Link Electrosystems.
From there....upgrade rod and pistons, turbo cam with springs and retainers, then run about 12-15 psi and hold on!
Old Jan 8, 2004 | 05:08 PM
Default Re: mods after installing an edelbrock turbo kit (Marauder)
No actually Im at 96% because I called Evil Drew M a something rather. Im just sick of dumbass questions that have already been answered. I think ill just quit posting and actually READ, which is what 98% of the people who ask questions should do.
EM2Fiend
Honda Civic (2001 - 2005)
16
Jun 25, 2007 01:13 PM
ZakkWylde
Jun 8, 2007 01:10 PM
walsh22
11
Nov 8, 2006 04:22 PM
B00ST2nR
May 26, 2004 07:49 PM
SpyderZEX
Aug 21, 2003 12:20 PM
