used car, valve adjustment?
Old Jan 6, 2004 | 06:00 AM
d16y8EL's Avatar
Default used car, valve adjustment?
I got the car used with 104k on it, but i have no idea if it has gotten a valve adjustment yet. Should i get one done? what does it do?
Old Jan 6, 2004 | 06:13 AM
westsidejdmyo's Avatar
if you're mechanically able i'd check them yourself, adjusting the gaps to the correct spec will improve performance aside from other things..a quick and easy check would be to listen for noise from the head at idle when the car is warm, if you can hear tapping clearly from the head then you probably better adjust them
Ryanwill86
Jan 14, 2009 06:04 PM
Dackonn
Nov 25, 2007 03:04 AM
acurateg96
Feb 6, 2006 03:24 AM
maxxd97
May 23, 2005 08:12 PM
XenonDepot
Apr 18, 2003 12:44 AM
