spark plugs in 8 heat range for hondas?
Old Jan 5, 2004 | 11:28 PM
marc.ejay-twenty's Avatar
Default spark plugs in 8 heat range for hondas?
does anyone know any manufacturer part number for a plug in the 8 heat range? i have a 00 si and the stock plug heat is a 6...so i'm trying to run 2 steps colder. i used ngk bkr7e's at the track last weekend and when i pulled them, the ground electrode was half disintegrated and the center electrode insulator was broken...the result of detonation. thanks
-marc
Old Jan 5, 2004 | 11:49 PM
MaxSterling's Avatar
Default Re: spark plugs in 8 heat range for hondas? (marcdogg816)
enjoy
ngk 7173 racing plugs
http://www.ngk.com/results_cro...7&y=4
Old Jan 6, 2004 | 12:00 AM
Default Re: spark plugs in 8 heat range for hondas? (MaxSterling)
hey thanks!
Old Jan 6, 2004 | 12:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcdogg816 &raquo;</TD></TR><TR><TD CLASS="quote">hey thanks!</TD></TR></TABLE>
look bottom right chart, you see bkr7e and to the left of it ngk 7173
Old Jan 6, 2004 | 12:06 AM
i noticed that these 7173 plugs do not have a resistor. are they safe to run in honda motors?
Old Jan 6, 2004 | 12:07 AM
according to that chart bkr7e doesn't have resistor either
Old Jan 6, 2004 | 12:09 AM
interesting because the sparkplugs.com partsfinder says the the bkr7e does have a resistor while the r5672a-8 does not. have you run these plugs?
Old Jan 6, 2004 | 12:10 AM
i use bkr7e
Old Jan 6, 2004 | 12:12 AM
ok thanks. i'll try them out.
Old Jan 6, 2004 | 12:13 AM
sharkcohen's Avatar
I'm running R5672A-8 on my H22.
Old Jan 6, 2004 | 06:45 AM
JDogg's Avatar
Default Re: spark plugs in 8 heat range for hondas? (sharkcohen)
denso iridium ik22 is the same as a 7 heat range ngk. denso goes all he way up to 32 heatrange.
Old Jan 6, 2004 | 07:42 AM
VaporTrail's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcdogg816 &raquo;</TD></TR><TR><TD CLASS="quote">i noticed that these 7173 plugs do not have a resistor. are they safe to run in honda motors?</TD></TR></TABLE>
yes, and we've also used these in the 9 heat range. NGK just came out with the iridiums in 9 heat range too....
Old Jan 6, 2004 | 08:01 AM
Gravy's Avatar
Default Re: spark plugs in 8 heat range for hondas? (VaporTrail)
v power num 7s are pn 4091.
v power num 8s are pn 4554.
v power num 9s are pn 5238.
Old Jan 6, 2004 | 12:40 PM
Default Re: spark plugs in 8 heat range for hondas? (Gravy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gravy &raquo;</TD></TR><TR><TD CLASS="quote">v power num 7s are pn 4091.
v power num 9s are pn 5238.</TD></TR></TABLE>
these are non-project tips, electrode sits inside plug housing. if you want something similar to bkr7e but in range 8 then its the ngk 7173 (also V power electrode copper)
Old Jan 6, 2004 | 01:26 PM
KrautFed's Avatar
I run BKR7E's ...lots of boost, nitrous, and lots of timing. (VW though)
Here's my writeup on them: http://forums.vwvortex.com/zerothread?id=1138834
Old Jan 23, 2004 | 10:28 AM
tthame1's Avatar
Default Re: spark plugs in 8 heat range for hondas? (KrautFed)
Doesn't a Honda need the BKR7E-11??? The one with the resistor?
Old Jan 23, 2004 | 10:29 AM
b18bturbo's Avatar
Default Re: spark plugs in 8 heat range for hondas? (tthame1)
we run r5671-a 8-12 depending on what conditons there are. Plugs can be had any hot rod store.
Old Jan 23, 2004 | 11:32 AM
DLB1994's Avatar
Default Re: spark plugs in 8 heat range for hondas? (b18bturbo)
am running 9's right now
killercrx91
Honda Civic (2006 - 2015)
15
Sep 25, 2008 12:51 PM
OneCrzySetup
Nov 17, 2006 11:53 AM
Turbo-charged
Jun 25, 2006 07:04 PM
Phatch99
Sep 8, 2005 12:39 PM
99turbosi
Jun 9, 2003 11:50 PM
