spark plugs in 8 heat range for hondas?
does anyone know any manufacturer part number for a plug in the 8 heat range? i have a 00 si and the stock plug heat is a 6...so i'm trying to run 2 steps colder. i used ngk bkr7e's at the track last weekend and when i pulled them, the ground electrode was half disintegrated and the center electrode insulator was broken...the result of detonation. thanks
-marc
-marc
Re: spark plugs in 8 heat range for hondas? (marcdogg816)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcdogg816 »</TD></TR><TR><TD CLASS="quote">hey thanks!</TD></TR></TABLE>
look bottom right chart, you see bkr7e and to the left of it ngk 7173
Re: spark plugs in 8 heat range for hondas? (MaxSterling)
interesting because the sparkplugs.com partsfinder says the the bkr7e does have a resistor while the r5672a-8 does not. have you run these plugs?
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcdogg816 »</TD></TR><TR><TD CLASS="quote">i noticed that these 7173 plugs do not have a resistor. are they safe to run in honda motors?</TD></TR></TABLE>
yes, and we've also used these in the 9 heat range. NGK just came out with the iridiums in 9 heat range too....
Re: spark plugs in 8 heat range for hondas? (Gravy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gravy »</TD></TR><TR><TD CLASS="quote">v power num 7s are pn 4091.
v power num 8s are pn 4554.
v power num 9s are pn 5238.</TD></TR></TABLE>
these are non-project tips, electrode sits inside plug housing. if you want something similar to bkr7e but in range 8 then its the ngk 7173 (also V power electrode copper)
I run BKR7E's ...lots of boost, nitrous, and lots of timing. (VW though)
Here's my writeup on them: http://forums.vwvortex.com/zerothread?id=1138834
Re: spark plugs in 8 heat range for hondas? (tthame1)
we run r5671-a 8-12 depending on what conditons there are. Plugs can be had any hot rod store.
killercrx91
Honda Civic (2006 - 2015)
15
09-25-2008 12:51 PM
Turbo-charged
06-25-2006 07:04 PM
