weird rattling sound...help
Old Jan 5, 2004 | 06:33 PM
JDM_Type-R's Avatar
Default weird rattling sound...help
for some reason, whenever i keep the throttle at about 1250 or 1300 RPM this weird sounding rattle ..or kinda like shatter sound comes from i think the front of the car. the sound usually isnt there when i am accelerating or decelerating for some reason. what could this be? anybody know? any info appreciated. thanks alot.
Old Jan 5, 2004 | 07:14 PM
mstewar's Avatar
Default Re: weird rattling sound...help (JDM_Type-R)
pop the hood and have a buddy take a listen..
heatshield maybe? "the front of the car" is kinda vague.. A LOT of stuff up there could be rattling..
Old Jan 5, 2004 | 07:30 PM
nightrider's Avatar
any recent mods? regardless, what are your mods?
Old Jan 5, 2004 | 07:57 PM
PlikityPLAH's Avatar
chattering clutch??
Old Jan 5, 2004 | 08:03 PM
JjuuN R's Avatar
a chattering clutch won't sound too much like a rattle. i had the same problems, after so long i just got so fed up with it i took every one of my exhaust heat shields off.
another thing it might be are the tension springs for the exhaust, i've heard a couple people complain about them and i as well had the same problem. i'm not using the tension springs/heat shields anymore and i have no more rattles
Old Jan 5, 2004 | 11:55 PM
JDM_Type-R's Avatar
Default Re: (JUN.R)
what causes a chattering clutch..?
also, the cars been out in the cold the past couple of days..could that have caused anything?
Old Jan 6, 2004 | 12:09 AM
JjuuN R's Avatar
naw
Old Jan 6, 2004 | 01:41 AM
JDM_Type-R's Avatar
Default Re: (JUN.R)
what causes a chattering clutch? ill take off all heatshields and see what happens.
Old Jan 6, 2004 | 01:51 AM
JjuuN R's Avatar
bad throwout bearing, or could just be signs of wear
Old Jan 6, 2004 | 02:52 AM
MiraiZ's Avatar
Default Re: (JDM_Type-R)
also broken teeth on the pressure plate diaphram...
Old Jan 6, 2004 | 03:03 AM
JjuuN R's Avatar
Default Re: (MiraiZ)
slightly bent teeth will do it too
Old Jan 6, 2004 | 04:34 AM
RaVAGE00's Avatar
New User
Default Re: (JUN.R)
If you have a high flow cat, it could be the combs rattling....
Vague
Apr 26, 2015 01:05 PM
NoahOneill
19
Nov 7, 2005 10:13 AM
ej20_chris
Sep 23, 2001 03:33 PM
