OMG B&M Tech Support---MUST READ!! Regarding FPR
Old Jan 5, 2004 | 02:22 PM
baphomet's Avatar
Default OMG B&M Tech Support---MUST READ!! Regarding FPR
After reading a few threads on FPRs namely this one and this one, I began to wonder how my B&M FPR would react when referencing boost. My logic tells me 1:1, how ever I am very open minded and love to learn new things. Some people have confirmed there stock ones are 1:1 while others have confirmed they are not. (diff. stock regulators maybe) Some people have said that 99-00 civic si are not 1:1. (checked with in car FP gauge). When you install the B&M on the factory FPR you change out the spring, so I just wanted to hear exactly how it behaves from someone who would surely know.
I head over to B&M's website with the idea of emailing them. They do not have email. Fine I think, I will just call over there.
Here is how my conversation with the B&M "tech support" guy went:
B&M: b&m.
Me: I installed the CommandFlo Fuel Pressure Modifier on my 99 honda civic si and was wondering how it would react when referencing boost. Would it raise the fuel pressure on a 1:1 ratio with boost?
B&M: Is that a super charger?
Me: Um.....The car will be turbo.
B&M: That is not a boost one.
Me: What?
B&M: That is a vacuum.
Me: What do you mean?
B&M: That one only works with draw not boost.
Me: So you are saying if positive pressure is applied to the fuel pressure regulator nothing will happen?
B&M: Yup. Might blow out the diaphragm.
I know for a fact that stock FPRs are fine on boosted cars, and I know several people on this board who have run with the B&M hack FPR with boost and no problems. The diaphragm used on both is the same factory one. Not to mention on B&M's website they sell it for turbo eclipses (admittingly it would use the stock eclipse FPR as a base).
I am in utter shock and disbelief. Am I missing something? Am I the one that needs mental help?
Old Jan 5, 2004 | 02:45 PM
Sonny's Avatar
Default Re: OMG B&M Tech Support---MUST READ!! Regarding FPR (slashDEVslashNULL)
Holy engrish, batman!
I tried 3 stock FPR's in my 2000 Civic Si. They all came from different 99-00 Civic Si's. I had in-car boost and fuel pressure gauges and observed this:
#1) My original one -- fuel pressure did not rise AT ALL under boost
#2) One I bought as a spare -- fuel pressure did not rise under boost
#3) Bought because I drilled a hole in #2 -- Fuel pressure DID rise under boost, but not 1:1. It was 1:1 up to about 6 psi. Then it was like 0.5:1 up to 9 psi.
These were all stamped "KEIHIN NR-1"
My conclusion: If you want a 1:1 FPR, but an AEM or Aeromotive...stock ones are a crap shoot.
Sonny
Old Jan 5, 2004 | 09:56 PM
boredracer408's Avatar
Default Re: OMG B&M Tech Support---MUST READ!! Regarding FPR (Sonny)
So can't u just add a check valve on the the stock or aftermarket fpr so it sees no boost?
I've got an AEM fpr and is the AEM 1:1?
Old Jan 5, 2004 | 10:06 PM
5thgencivic's Avatar
Default Re: OMG B&M Tech Support---MUST READ!! Regarding FPR (boredracer408)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boredracer408 &raquo;</TD></TR><TR><TD CLASS="quote">So can't u just add a check valve on the the stock or aftermarket fpr so it sees no boost?
I've got an AEM fpr and is the AEM 1:1?</TD></TR></TABLE>
You want the fpr to see boost... The AEM from what I understand is pretty close to 1:1. I'm using one on my setup.
Old Jan 6, 2004 | 09:39 AM
97F22B2's Avatar
I have the B&M in my car right now without boost and my 255 and 440cc injectors. The pressure just bounces at 45psi no matter what i do, even at WOT.
Old Jan 6, 2004 | 11:20 AM
IN VTEC's Avatar
Default Re: (97F22B2)
Is your FPR manifold pressure-referenced? It should vary as a function of manifold pressure/vacuum.
Old Jan 6, 2004 | 11:28 AM
redboost10's Avatar
Default Re: (IN VTEC)
any comments on this aeromitive?
http://www.jegs.com/cgi-bin/nc...r=361
Old Jan 6, 2004 | 11:41 AM
97F22B2's Avatar
me?
Old Jan 6, 2004 | 12:09 PM
IN VTEC's Avatar
Yeah.
Silverbeast's Avatar
Default Re: (tgh99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">any comments on this aeromitive?
http://www.jegs.com/cgi-bin/nc...r=361</TD></TR></TABLE>
The regulators also have a 1/8 NPT gauge port, and are boost referenced (if you are running a turbo or supercharger).
I know that i run this one http://www.jegs.com/cgi-bin/nc...r=361 and it is also 1:1 and works flawlessly with boost.
Old Jan 6, 2004 | 12:54 PM
*Boostwerks*'s Avatar
Just to add to the pot of controversy...
This was taken from a post a while back Quoted from BoostedHybrid...
"all fuel pressure regulators will be 1:1 with boost".
I know Boosted knows his ****, but this just doesn't corrispond with what everyone else has said.
Old Jan 6, 2004 | 01:17 PM
Default Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">Just to add to the pot of controversy...
I think that they are to a certain extent, like Sonny tested and saw.
Old Jan 6, 2004 | 02:49 PM
chad's Avatar
Moderator
Default Re: (HoustonSi)
i would tend to believe that the AEM units act the same way cause my aem diaphram blew out!! 4 hours of trouble shooting and being stuck in charlotte.....
hmmm....this is good info!
Old Jan 6, 2004 | 05:48 PM
97F22B2's Avatar
My FPR is hooked up stock if that is what you mean. It did this right after i installed my fuel pump.
Does the same thing on my friends 2G GSX
Old Jan 6, 2004 | 07:03 PM
Jeff33S's Avatar
Default Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">i would tend to believe that the AEM units act the same way cause my aem diaphram blew out!! 4 hours of trouble shooting and being stuck in charlotte.....
yeah bad expierence with the aem as well......I know several people on here have luck with AEM's but my diaphram blew out on a brand new unit in just under 2 days of driving. Try an aeromotive....
-Jeff-
Old Jan 8, 2004 | 07:57 AM
97F22B2's Avatar
So should i get the AEM or not. I need a new FPR ASAP
Old Jan 8, 2004 | 08:20 AM
Default Re: (Jeff33S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff33S &raquo;</TD></TR><TR><TD CLASS="quote">
-Jeff-</TD></TR></TABLE>
After reading this I'm going to bring my stock regulator to the dyno with me just in case I picked up a used aem and have been running it, but it hasn't seen boost yet.
Old Jan 8, 2004 | 08:42 AM
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97F22B2 &raquo;</TD></TR><TR><TD CLASS="quote">So should i get the AEM or not. I need a new FPR ASAP </TD></TR></TABLE>
get one, those issues have since been fixed AFAIK.
Old Jan 8, 2004 | 08:47 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (slashDEVslashNULL)
is there a stock location aeromotive fpr for a 00 ex???????
Old Jan 8, 2004 | 08:49 AM
baphomet's Avatar
Default Re: (Hella_JDM)
these might work
Old Jan 8, 2004 | 09:26 AM
Short Round's Avatar
b&M....vortech... same thing right?
turbotime
Apr 22, 2006 04:51 PM
kaj
Aug 16, 2005 11:07 PM
fjt
May 5, 2005 01:52 PM
mskibbz-T
Aug 23, 2003 06:40 PM
JDM EG2
Mar 24, 2003 10:00 AM
