Bent valves??? how to tell.......
Old Jan 5, 2004 | 01:47 PM
USDM 4G VTEC's Avatar
Default Bent valves??? how to tell.......
what methods u guys use to see if u have bent valves???
i drove on rain the other day and my motor started ******* idle like ****
sounds like misfire or blown spark plug
i checked spark plugs and they work, checked fuel injectors and works fine
NO CODES!!
no overreving, and or misshifts, or downshifts
and idles rough... but after 2200 rpms it drives fine and without hessitation and or problems or loose of power... no ticking at all neither and i am using a doctors tetoscope and all.... no out of ordinary ticking
spark plugs look dry without any condensation on them... so i dont beleive water spams them
now i am inclinin into mechanical problems... i know my motor didnt suck any water at all... the filter was kinda dry
now other than compression test... and see wich one is low... and doing a leakdown test... meanwhile i get a hold of those,. what tricks u guys have used to see if theres any bent valves.
and while we at it, lets make this a search topic worthy..... search for this topic on this forum sucked
Old Jan 5, 2004 | 02:08 PM
VtecKiDD's Avatar
Default Re: Bent valves??? how to tell....... (USDM 4G VTEC)
it will tick REALLY Loud an you can get blow by, ie oil coming back out into the intake manifold . do a comp test, you will know def then
Old Jan 5, 2004 | 02:16 PM
Outsane's Avatar
Default Re: Bent valves??? how to tell....... (VtecKiDD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">do a comp test, you will know def then</TD></TR></TABLE>
Old Jan 5, 2004 | 02:33 PM
redeyeef2's Avatar
Default Re: Bent valves??? how to tell....... (Outsane)
To be completely sure you would want to perform a Leak-down test. This would better indicate which valve(s) are bent.
http://www.redeyefabrication.com
Old Jan 5, 2004 | 03:49 PM
yellowcrx1991's Avatar
You check your spark plug wires' resistance? I had massive backfire all the way up to 3k found out two of my four wires were bad. Replaced them and haven't had a problem since.
Old Jan 6, 2004 | 07:41 AM
Default Re: Bent valves??? how to tell....... (yellowcrx1991)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowcrx1991 &raquo;</TD></TR><TR><TD CLASS="quote">You check your spark plug wires' resistance? I had massive backfire all the way up to 3k found out two of my four wires were bad. Replaced them and haven't had a problem since.</TD></TR></TABLE>
not yet
but i am going to do so soon......
even tho i am getting spark and not sputerin any time after 2k rpms... hmmm
cables arent even 6 mths old... doesnt mean they cant go bad.,... but still..... i should see any other signs other than idle on cables....
Old Jan 7, 2004 | 05:01 AM
well got around to do some compression test.
Results:
190, 190, 145, 190
#2 was done 3 times to get a baseline constant reading... indeed somethings wrong
time for a leakdown test and see where the air is escaping to... ill keep ya posted
Old Jan 7, 2004 | 05:02 AM
VtecKiDD's Avatar
yup , thats def a problem, good luck
gsrvx
Sep 30, 2006 09:50 PM
Layziebtnh055
May 12, 2004 07:06 AM
311
Jan 17, 2003 08:29 PM
B00ST2nR
Sep 22, 2002 01:00 PM
