92 d16z6 in ef...what mounts?
Old Jan 5, 2004 | 01:17 PM
mitsuman's Avatar
Default 92 d16z6 in ef...what mounts?
i searched but didnt find specific answers. any info appreaciated.
Old Jan 5, 2004 | 01:20 PM
FAST AS's Avatar
Default Re: 92 d16z6 in ef...what mounts? (mitsuman)
u have to use your stock mounts
Old Jan 5, 2004 | 01:24 PM
91civicDXdude's Avatar
use your stock *mount*. since you are using your stock tranny ( the hydraulic tranny has differnt mount locations and your car doesnt have the slave cylinder for hydraulic clutch), you just use your one stock driver side engine mount on the d16z6 engine
Old Jan 5, 2004 | 01:30 PM
mitsuman's Avatar
Default Re: (91civicDXdude)
thnx for the quick response. so i need the 88-91 driver side mount. then what other mounts. im wanting to go cable tranny so can i use the stock mount for that? since the 92 has hydro tranny and mounts different.
Old Jan 5, 2004 | 01:41 PM
USDM 4G VTEC's Avatar
Default Re: 92 d16z6 in ef...what mounts? (FAST AS)
u need to take the mount off ur old motor.. even the part that screws into the block..
then replace the Z6 mounts with them
viola!
Old Jan 5, 2004 | 01:48 PM
mitsuman's Avatar
Default Re: 92 d16z6 in ef...what mounts? (USDM 4G VTEC)
what about the trany?
Old Jan 5, 2004 | 01:52 PM
FAST AS's Avatar
are u using the 88-91 tranny if u are use the mount off it
Old Jan 5, 2004 | 02:26 PM
Artful Dodger's Avatar
you'll have to cut the timing belt cover when you swap the mount from your old motor over too (swap actual bracket that bolts to the motor). Use the z6 mounts for the other mount points
Old Jan 5, 2004 | 02:31 PM
mitsuman's Avatar
Default Re: 92 d16z6 in ef...what mounts? (Artful Dodger)
cool. thnx guys.
phrack3r
Jan 11, 2010 10:57 AM
4twenty_CRX
Jun 13, 2007 07:34 PM
bbrian
May 29, 2005 08:39 PM
97civicdx
Feb 9, 2005 12:32 PM
al3e
11
May 16, 2004 10:59 AM
