ITR ECU in 00 SI ? Question
Old Jan 5, 2004 | 08:02 AM
OUTKAST_R's Avatar
Default ITR ECU in 00 SI ? Question
has anyone tried it ? and is it worth it.. Currently i have an si with a type r top end ?
and i want to know if i get an r ecu will it run better ? i am getting a 00 r ecu
should i have any problems and what do you guys think ?
Old Jan 5, 2004 | 08:07 AM
Dr. EKology's Avatar
Default Re: ITR ECU in 00 SI ? Question (jdmwanabe)
Since the R ECU is programed for a 1.8, I would guess it would probably dump a little too much fuel into your 1.6 . A better Idea for you would be to run a OBD2-OBD1 conversion along with a chipped P28.
Old Jan 5, 2004 | 08:19 AM
boostng r's Avatar
a
ok if u are getting the usdm itr ecu it wont work because itr has a special chip in the ignition so the ecu and the ignition have to be the same
Old Jan 5, 2004 | 08:36 AM
TeamNextGenChris's Avatar
as said above you'll have problems with the immobilizer...
if you really want a different ECU i say go with an OBDI jumper and a chipped OBDI ECU.
chris
Old Jan 5, 2004 | 08:45 AM
EG8R's Avatar
Default Re: ITR ECU in 00 SI ? Question (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">as said above you'll have problems with the immobilizer...
chris</TD></TR></TABLE>
Best idea/better way to do it
I read this in the EF forum, first thing I thought was immobilizer....
Old Jan 17, 2004 | 07:52 AM
OUTKAST_R's Avatar
Just a heads up i put the ecu in last night and the car feels 100% better
Old Jan 17, 2004 | 07:56 AM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: (jdmwanabe)
i always told it would not work but i guess it does
Old Jan 17, 2004 | 09:21 AM
OUTKAST_R's Avatar
it works you just have to move a pin and take the imm out. you have a chk light but the ecu is not in limp mode
OUTKAST_R
Jan 11, 2005 03:15 PM
OUTKAST_R
Jan 5, 2004 08:01 AM
sinatra
Dec 25, 2003 04:18 PM
turbotypeR@SPEC
Dec 23, 2001 08:44 AM
d0nkeyxPunch
Dec 9, 2001 01:03 PM
