What causes the cap to shock people..
Old Jan 5, 2004 | 06:04 AM
tgreaves's Avatar
Default What causes the cap to shock people..
On my crx I am trying to adjust my ignition timing.. When I grab the dizzy cap in a certant way it shocks the hell out of me.. Im not touching any plug wires or anything like that.. Do I need a new cap or is this normal??
Old Jan 5, 2004 | 10:46 AM
Perfectionist's Avatar
Default Re: What causes the cap to shock people.. (tgreaves)
The spark is high tension. If you're leaning against the fender you could provide enough of a path to ground to get shocked. I think it's normal, but then I haven't tried it myself. Could be you have a hairline crack in the cap or carbon deposits on the inside of the cap that make it happen easier.
Old Jan 5, 2004 | 10:47 AM
tgreaves's Avatar
Default Re: What causes the cap to shock people.. (Perfectionist)
Hmmm.. Would using a pair of gloves stop it..
Old Jan 5, 2004 | 01:40 PM
PHiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm.. Would using a pair of gloves stop it.. </TD></TR></TABLE>
Maybe not, but disconnecting your battery would
-PHiZ
Old Jan 5, 2004 | 01:51 PM
tgreaves's Avatar
Default Re: What causes the cap to shock people.. (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">
-PHiZ</TD></TR></TABLE>
Kinda hard to keep the motor running without a battery.. It would but thats bad, another story all together.. Im trying to adjust the timing with the engine running..
Old Jan 5, 2004 | 02:18 PM
RCautoworks's Avatar
Rubber gloves and a good pair or boots or shoes with a rubber sole will help.
Old Jan 5, 2004 | 02:26 PM
yellow_jacket's Avatar
I have grabbed an awful lot of caps and wires. You really shouldn't get shocked unless there is a problem with the cap. It probably has a hairline crack in it.
Old Jan 5, 2004 | 02:55 PM
PHiZ's Avatar
hit it with the timing gun, turn the ignition off, slide the cap, wash rinse repeat.
-PHiZ
Old Jan 5, 2004 | 05:37 PM
Jim Truett's Avatar
Default Re: (yellow_jacket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow_jacket &raquo;</TD></TR><TR><TD CLASS="quote">I have grabbed an awful lot of caps and wires. You really shouldn't get shocked unless there is a problem with the cap. It probably has a hairline crack in it.</TD></TR></TABLE>
Exactly. it sounds like it is time for a new cap and possibly plug wires too.
Old Jan 5, 2004 | 06:53 PM
bsracing's Avatar
sounds like you need a new cap, an easy way to check where its leaking at is to mist the area with water while its running and see if theres any sparks, do it in a dark area so you can see it better.
Patman
Audio / Security / Video
10
Jan 5, 2007 08:18 AM
DjBij099
Oct 27, 2006 02:03 AM
oblique
Nov 25, 2004 11:27 PM
Chewie
Nov 1, 2004 09:09 AM
Boostless97Lude
Jul 9, 2003 05:52 AM
