Proportioning Valve or Brake Lines?
When I hit the brakes my car steers to the right. Is this the Proportioning Valve or the brake lines. My brake pedal also goes down pretty low. Could they need to be bled or is there air somewhere in the lines?
Yes I suppose it could be any of those things. Check them out.
Inspect calipers, pads, & rotors. Pads worn down? Rotors bad? Caliper slide pins stuck? Pad anti-rattle springs & clips assembled correctly?
Bleed the brakes completely. That gets air out of the lines.
EngineNoO9
Honda Motorcycles
22
May 25, 2006 04:58 PM
slut
Oct 29, 2003 12:57 PM
