valve adj.. now problem.. help??
Old Jan 4, 2004 | 07:38 PM
tangb2023
Guest
Posts: n/a
Default valve adj.. now problem.. help??
hey guys i just did a valve adj on moms 92 accord ex.. when i started, it seems that the clearance were too tight.. so i redid all of them.. .010 intake ane .012 on exaust. now i could hear the rattle more than ever..
i redid it again, all inspecs.. any insight? is it because who ever did it before; left too little clearance and that is why it is worse now???
thanks a bundle.
i had this is accord forum.. no help.
Old Jan 4, 2004 | 07:54 PM
Sketch_hs's Avatar
weird. good luck.
get this guy some help.
Old Jan 4, 2004 | 08:25 PM
JwM's Avatar
JwM
Default Re: (Sketch_hs)
Hmmmm... weird. The only thing I can think is to do it again, just to be sure, and this time when you slide the feeler gauge around, once you feel some drag (it must still be able to slide freely, but just with a little drag...) after you do that, test the gap once more, and take the gauge up to the next bigger size, which should NOT fit.
Another thing is, generally unless your valves are pretty off to begin with it shouldn't make much difference in the overall sound, so to me that says they are still off somewhere, but as far as whoever did it before messing it up, I don't know if that is a possibility or not... I hope you get it fixed, and good luck!!!
Old Jan 4, 2004 | 08:49 PM
tangb2023
Guest
Posts: n/a
Default Re: (MaboroshiNinja)
^^ i did it twice.. and i did use the next size up.. i did adjustments on all my eg motors and had no problem..
anyone else??
Old Jan 4, 2004 | 09:33 PM
TeamNextGenChris's Avatar
Default Re: valve adj.. now problem.. help?? (tangb2023)
are you doing it with the engine cold(clearances change when hot)?also,after you tighten the jam nut,are you rechecking the clearance?it's easy to accidentally turn the adjuster when tightening the jam nut,changing the adjustment.
chris
Old Jan 5, 2004 | 08:36 PM
tangb2023
Guest
Posts: n/a
Default Re: valve adj.. now problem.. help?? (TeamNextGenChris)
i did it right.. i double checked, and the motor was cold over night..
dont know why was there, not enough clearance before i started...
anyone ever had their valve under clearance before thay started...????
Old Jan 5, 2004 | 08:42 PM
ATS*Mark's Avatar
OG triple OG
i had that problem too , but it was because im an idiot
it helped me by doing the "go-no go" trick....
pick ur desired thickness , tighten it to it , then slip the next ticker feeler in between , it shouldnt fit . hense the go and no go......worked for me
Old Jan 6, 2004 | 07:50 AM
tangb2023
Guest
Posts: n/a
Default Re: valve adj.. now problem.. help?? (Hella_JDM)
so u leave the desired guage inbetween and leave it there trying to add in the next size feeler right??
i just do it and then take it out and put the next guage in and it does not fit to make sure.. i redid it twice.
Old Jan 6, 2004 | 04:27 PM
ATS*Mark's Avatar
OG triple OG
ya put the desired feeler in , make sure it slides in , and the next higher up one shouldnt....
Old Jan 6, 2004 | 05:22 PM
EK MONEY's Avatar
How is the oil level? Is it receiveing proper oil the the head?
Old Jan 6, 2004 | 05:28 PM
tangb2023
Guest
Posts: n/a
Default Re: valve adj.. now problem.. help?? (Peagreenhatch)
i think so.. didi not really check.. why??
Old Jan 30, 2004 | 10:04 PM
civicmon's Avatar
Bumped to the top since I have the same exact problem on my 96 ex civ.. i did it twice, checked the clearances and now it runs crappy and sounds horrible.
any suggestions?
Old Jan 30, 2004 | 10:09 PM
Richard.'s Avatar
Default Re: valve adj.. now problem.. help?? (civicmon)
A rattle? what kind of rattle? like a clicking noise? might sound dumb, but check that the camgear isnt rubbing on anything?
Old Jan 30, 2004 | 10:11 PM
civicmon's Avatar
Default Re: valve adj.. now problem.. help?? (Spoon)
in my case.. it sounds like a rattling valve x10....that rattling valve on cold AMs x10 and never goes away.
Old Jan 31, 2004 | 10:50 AM
civicmon's Avatar
ttt
anyone?
numotive
Oct 6, 2016 06:57 PM
Honda knowledge
Engine Management and Tuning
Dec 10, 2013 11:13 PM
avaldez
May 28, 2008 07:50 PM
_Endless_
Jul 7, 2004 06:24 AM
daywong
Oct 29, 2003 10:15 PM
