Need some help from fellow R members.
Old Jan 4, 2004 | 05:58 PM
ITR-Spoon's Avatar
Default Need some help from fellow R members.
I have a check engine light, number 67. When i look it up it said the Catalyst system Efficiency was Below Threshold malfunctioning or defective catalyst system.
I need someone to help me find out the possible causes. Thank You
Old Jan 4, 2004 | 06:06 PM
py1188's Avatar
Default Re: Need some help from fellow R members. (PY-ITR-#977)
Catalytic converter or secondary 02 sensor. One of them is bad
Old Jan 4, 2004 | 06:09 PM
Ferrell's Avatar
Default Re: Need some help from fellow R members. (py1188)
stock header/cat?
Old Jan 4, 2004 | 06:13 PM
ITR-Spoon's Avatar
I was thinking it was the secondary 02 sensor, but my cat maybe be going bad, because its a high flow cat also. thanks guys.
Old Jan 4, 2004 | 06:16 PM
B2FiNiTY's Avatar
Probably your aftermarket cat.
Old Jan 4, 2004 | 09:41 PM
Kicker773's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py1188 &raquo;</TD></TR><TR><TD CLASS="quote">Catalytic converter or secondary 02 sensor. One of them is bad</TD></TR></TABLE> i believe that is it
Old Jan 4, 2004 | 10:26 PM
WarrenB's Avatar
As soon as I put on my T1R race cat (which is really just a straight pipe), the CEL came on. The secondary O2 kicks out the Catalyst Deterioration error.
I want to swap to ODB1 when I upgrade to a Hondata.
On a side note: I have heard that the Spoon ECU will not give you any problems with the Check Engine Light coming on if you have a high flow (or cat-by pass) cat even though it is an ODB2 ECU... Can anyone provide any insight to this?
Old Jan 4, 2004 | 10:32 PM
esponet's Avatar
spoon ecu does not look for secondary O2. almost any aftermarket cat (high flow or not) will have problem after using them for a while, they just don't last very long. replace the cat or go obdI. you could fool the ecu on thinking its still has a good cat. the secondary O2 only need to see clean hot air.
rjmq06
Sep 12, 2010 03:05 PM
baiwldrnner
Honda Civic (2001 - 2005)
13
Jul 15, 2007 10:04 AM
ITR0952
Mar 6, 2005 06:13 AM
BlueIntegraBoy
Jul 26, 2003 04:46 PM
redciviclx14
10
Jul 8, 2003 07:39 PM
