Do your trannies grind when cold?
Old Jan 4, 2004 | 04:53 PM
fcuked's Avatar
Default Do your trannies grind when cold?
I left my car outside overnight last night because it's leaking a bit of oil because one of the drivesafts can't be put in all the way. Anyway every day before i go anywhere, i've been checking the tranny oil and i add mtf if i need to. This has been going on for the past 3 days.
Now when i start driving after the car is relatively warm the tranny grinds 2nd and 3rd gears, when the car is up to normal operating temp, the grinding stops completely.
Modified by 1.8 HB at 10:47 PM 1/4/2004
Old Jan 4, 2004 | 05:04 PM
G U E C O's Avatar
no
Old Jan 4, 2004 | 05:54 PM
leadfoot78's Avatar
Default Re: (stock93cx)
No, weather it's 50F or 120F tranny always shifts the same. But if you have a problem like that u may be using the wrong lubricant.
Old Jan 4, 2004 | 06:25 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: Do your trannies grind when cold? (1.8 HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8 HB &raquo;</TD></TR><TR><TD CLASS="quote">
Now when i start driving after the car is relatively warm the tranny grinds 2nd and 3rd gears, when the car is up to normal operating temp, the grinding stops completely.</TD></TR></TABLE>
Use better oil.
Old Jan 4, 2004 | 06:27 PM
JDMlyfestyle's Avatar
Gm Synchromesh friction
Old Jan 4, 2004 | 06:48 PM
fcuked's Avatar
Default Re: (JDMlifestyle)
Isn't honda MTF, the best i can possibly use?
Briman2021's Avatar
Default Re: (leadfoot78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leadfoot78 &raquo;</TD></TR><TR><TD CLASS="quote">No, weather it's 50F or 120F tranny always shifts the same. </TD></TR></TABLE>
Yeah, mine shifts the same at 50* as it does any other time, but when it actually gets cold, like 5*, then it occasionally grinds a little bit, and is harder to get in gear, that stops when the car is warmed up though.
SOHC_MShue's Avatar
I use honda mtf
Old Jan 4, 2004 | 06:51 PM
moondoggy's Avatar
Default Re: Do your trannies grind when cold? (SOHC_MShue)
mine grinds just a bit before it warms up if it's below -20'ish F.....otherwise, it's doesnt
Old Jan 4, 2004 | 07:05 PM
there was a write up a couple weeks ago GM snychromesh friction won... sorry im not a good speller hope thats right
Zeus Zore's Avatar
Default Re: (Briman2021)
yeah cause there is a diffrendt if it is cold or not !!
HBK
13
Sep 17, 2006 11:26 AM
da6jdmteg
Mar 8, 2006 07:43 PM
DIYaccord
Dec 11, 2004 09:45 PM
fake mugen power
15
May 24, 2004 07:17 PM
int3gra
Oct 9, 2001 05:51 PM
