idle problem??? anyone??
Old Jan 4, 2004 | 03:49 PM
all_out_jdm's Avatar
Default idle problem??? anyone??
Modified by student_n1 at 5:03 PM 1/30/2005
Old Jan 4, 2004 | 03:51 PM
dsadas89das78934's Avatar
sounds like a vacuum leak to me, or the IACV filter could be clogged up.
Old Jan 4, 2004 | 03:56 PM
nY's FiNeSt's Avatar
Default Re: (soccaian)
there's a few things you should check that might help you
- clean the TB plate with some TB cleaner
- check all your vac lines for leaks
- IACV could possibly need to be replaced ( that fixed my idle surge )
- could be your TPS, try swapping that out if you have a spare
last thing you might wanna try is slightly adjusting the idle screw on the TB and see if that helps. Goodluck
Old Jan 4, 2004 | 04:12 PM
2jdm2's Avatar
i kinda have the same problem... jumps up and then down but mine goes from 900 rpm's or so too 500 or if im driving and stop at a light and put it into neutral car feels like its going to suddenly stal.... have h22a btw
Old Jan 4, 2004 | 04:18 PM
Smith Wise's Avatar
Default Re: (2jdm2)
spray carb cleaner all around the IM and TB and see if it starts bubbling. that should help you find the vaccum leak
have you recently done any work to your car?
Old Jan 4, 2004 | 05:40 PM
hybrid racing's Avatar
take a pic of your throttle body....
does it go away when you turn on your ac...
do you have a code?
have you checked the wiring going from the IACV to the ecu do you have 12 volts when the key is on...
Old Jan 4, 2004 | 05:41 PM
illicon2003
Guest
Posts: n/a
what they said ^^^^ or spark plugs/wires
Old Jan 4, 2004 | 06:26 PM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: (illicon2003)
Check your CEL codes.
Old Jan 4, 2004 | 08:42 PM
Default Re: (R_EG)
Modified by student_n1 at 5:04 PM 1/30/2005
Old Jan 16, 2004 | 05:09 AM
Did you get it fixed?
can you get a pic of the throttle?
good luck
Old Jan 16, 2004 | 05:31 AM
bigBOI_92DA9's Avatar
Default Re: idle problem??? anyone?? (annguy3)
WE HAVE THE SAME PROBLEM , BUT I DIDNT REALLY DO ANYTHING ON MINE ITS JUST AFTER A WHILE IT JUST IDLE BACK TO NORMAL PROBABLY FOR LIKE A COUPLE OF DAY OR 3 THE MOST THE IDLE WILL GO FROM 800 TO 1500 AND THEN THERE ARE TIMES THAT WHEN YOU STOP ON A TRAFFIC LIGHT THE CAR JUST DIES BUT YEAH YOU MIGHT WANNA CLEAN THE TROTTLE BODY AND CHECK THE VACUMM LINES OR SOMETHING CUZ THEIR MIGHT BE A LEAK
Old Jan 16, 2004 | 07:19 PM
DangBruhY's Avatar
Default Re: idle problem??? anyone?? (bigBOI_palooza)
My engine did it a while back. I first was told to change my Fast Idle Control Valve and it would fix it. It went away for a while.
Later I had cams put in my engine and it came back after that, so I took it to the shop to make sure the valves were set right. The guy checked my valves and turned up the idle. Didn't seem to go away.
I had to get my car smogged and was hoping it would stop for a few minutes. It didn't and on the SECOND try, I had to figure SOMETHING out before I had to pay this guy for passing. So I turned down the idle, and it went away.
JUST the other day, I took my car to Sears to see if my battery was going bad. After getting it back, I noticed that the battery terminal was cracked and my crazy idle was back.
I can't take it back, because there is no record of my car being there. They didn't do anything other than "test the battery." So they would call bullshit if I said they messed it up.
I don't know what the problem is either. I will be checking back to this thread to check out the suggestions.
Old Jan 24, 2004 | 07:58 AM
ok lets start from the basics:
-any codes?
-any vacuum leaks?
-what happens when you turn on the ac?
-what ecu are you running? jumper harness?
-what happens when you remove a vaccum line from the manifold?
let me know thanks
Old Jan 24, 2004 | 08:13 AM
DangBruhY's Avatar
Default Re: (6spdEG)
Mine has no codes
no leaks (that I know of)
Nothing happens when the AC is turned on
P30
I'll try that today.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6spdEG &raquo;</TD></TR><TR><TD CLASS="quote">ok lets start from the basics:
-any codes?
-any vacuum leaks?
let me know thanks</TD></TR></TABLE>
Old Jan 24, 2004 | 01:59 PM
ok coo let me know
Old Jan 25, 2004 | 11:19 AM
Br1anPham's Avatar
bump, interesting tread cause i ahve the same stupid idle problem almost
Old Jan 25, 2004 | 11:47 AM
Todapwr's Avatar
i have a idle problem 2
Old Jan 25, 2004 | 12:11 PM
DangBruhY's Avatar
Default Re: (TodaPwr)
What I want to know is that if SO many people are having this problem, why hasn't anyone posted a fix? Is this a problem that cannot be fixed? Or, are the right people not looking at this thread?
Old Jan 25, 2004 | 02:29 PM
The problem has many variables and something that fixes one persons car may not fix anothers.....
I can make a post walking everyone thru something like a flow chart and people can add there experience and we can get one big thread going for this problem.
Old Jan 25, 2004 | 02:34 PM
GTlvr82's Avatar
That is an outstanding Idea.....and we can get it stickied by Tom. You make the "flowchart" and we can start unfugging this stuff. One problem is the CYP sensor in the dizzy, IACV....vaccuum leak.
Old Jan 25, 2004 | 03:33 PM
DangBruhY's Avatar
Default Re: (GTlvr82)
That would be awesome!
Old Jan 27, 2004 | 12:01 AM
Br1anPham's Avatar
Default Re: (DangBruhY)
Theres should jsut be one BIG-O idle thead, built from all the other idle thead. Even if you search, there is way too many topis with all different kidns of variety, someone should just make one thead that covers as much problems and solutiosn as possible, w/ a section of unsolved problems or something? sorry for typos im bout to sleep.
Old Jan 30, 2004 | 07:18 AM
Sorry i have not updated there has been alot of emails about the K20 swap and more and more walk in customers daily .... i have not forgot....
Fast Idel control Valve.. Fix
https://honda-tech.com/zerothread?id=743179
92egSnatch
Mar 22, 2008 08:55 PM
gmuas
Mar 6, 2008 12:58 PM
crxfreak1117
Sep 8, 2007 07:05 PM
lude-tec
Mar 14, 2006 08:03 PM
kihun_cha
20
Sep 17, 2004 03:18 PM
